ᐅ Floor plan design for a new build modern semi-detached house with 6-meter ceiling height and 239 square meters of living space
Created on: 9 Nov 2025 23:46
lucaskilam
I am planning to demolish my existing semi-detached house and build a modern residential building on my property.
The new house will again be attached directly to the existing neighboring half.
The plot measures 1,027 sqm (about 11,060 sq ft), and the design comes from my architect.
I would appreciate honest and constructive feedback on the floor plan and room layout.
Elevations and floor plans are attached.
  • Plot size: 1,027 sqm (half share use for semi-detached house)
  • Slope: no slope, flat area
  • Site coverage ratio: 0.3
  • Floor area ratio: 0.5
  • Building envelope / building line / building boundary: according to development plan, semi-detached house permitted
  • Edge development: attached to existing neighboring half
  • Number of parking spaces: 2
  • Number of floors: 1.5 floors
  • Roof type: gable roof
  • Architectural style: modern, clean lines
  • Orientation: garden facing southwest
  • Maximum building height: 10 m (33 ft)
  • Other requirements: only one full storey allowed
Client requirements
  • Building type: semi-detached house, new build after demolition
  • Basement: no
  • Living area: approx. 239 sqm (2,572 sq ft)
  • Occupants: 5 persons (2 adults, 3 children)
  • Ceiling height in living area: approx. 6 m (20 ft)
  • Living/dining area: approx. 44 sqm (473 sq ft), open and bright
  • Office: home office on ground floor
  • Guest bedrooms: rare use (max. 2–3 times per year)
  • Architecture: open, modern, large windows
  • Construction method: solid construction
  • Kitchen: open with cooking island
  • Seating capacity: 6–8 people
  • Fireplace: not planned
  • Music/stereo wall: possible
  • Balcony / roof terrace: currently not planned
  • Garage / carport: double carport
  • Garden: low maintenance, for family use
  • Special features: high, open living area with gallery
  • Designed by: independent architect
  • Positive aspects: the open living area with gallery and high ceiling, generous lighting
  • Less favorable aspects: access to the gallery not yet optimal
  • Price estimate according to architect: approx. 850,000 euros (including fittings, excluding landscaping)
  • Personal budget limit: approx. 900,000 euros
  • Heating system: air-to-water heat pump with underfloor heating
  • Could be omitted: guest room on ground floor
  • Must have: high ceiling in living area, open kitchen, gallery
  • Reason for design: combination of modern living concept and development plan requirements (only 1 full storey, mandatory attachment)
  • Special features: despite semi-detached structure, a spacious feel through 6 m ceiling height and open gallery
I look forward to honest criticism and suggestions for improvement, especially regarding:
  • Floor plan layout
  • Lighting and window areas
  • Proportions with 1.5 floors
  • Practical everyday use (family with three children)
Thank you in advance for your feedback!
lucaskilam
Two-story floor plan of a house with kitchen, living room, and bedrooms
3D view of a brick house model with dormer windows, brick facade, and dark roof
Modern two-story brick house facade with large glass fronts, 3D rendering.
Section through a house showing roof, stairs, and foundation in raw construction state
16 Nov 2025 21:25
kbt09 schrieb:
You can’t plan anything completely separately from everything else.
I also like to think a bit independently, which is how I finally stopped here on Thursday/Friday.
The house length is 15 meters (49 feet), using the entire building plot. Then I got a bit carried away and added a conservatory. I figured there’s this second building plot for auxiliary buildings, usable area, barn, etc. So, just for demonstration.
While drawing, I thought it was too much for the length, but I didn’t want to delete it yet.
Because it inspired me to position this conservatory between the living room and the shed. The shed will get a side door, and there will be a better solution for the hobby/playroom as well.
Here is the current status (unfortunately, the tool can’t connect roofs when I use it)
3D view of a red brick house with a large glass veranda in the garden
3D model of a brick house with garden, cars, and a standing person in front.
Floor plan of a house with terrace, conservatory, living room, kitchen, and dining area.
2D floor plan of a house with bedrooms, rooms, bathroom, and stairs
lucaskilam
16 Nov 2025 23:25
I also like to keep things a bit flexible, so I basically stopped here on Thursday/Friday?
The house length is 15 meters (49 feet), using the entire building plot. Then, ambitiously, I added a conservatory. I thought there is a second building plot available for an ancillary building, utility area, stable, etc. So, just as a demonstration.
While drawing, I thought it might be too much for the length, but I didn’t want to delete it yet.
It actually inspired me to place this conservatory between the living room and the shed. The shed will get a side door, and there’s also a better solution for the hobby/playroom.
So here is the current progress (unfortunately, the tool doesn’t allow connecting roofs while I use it).
3D view of a red brick house with a large glass veranda facing the garden
3D model of a brick house with garden, cars, and a person standing in front
I think this is actually a good approach. Primarily, the goal is to bring more light into the house, right? What I like most about the architect’s floor plan is that the living and dining areas are designed as one large, open space. In general, I prefer layouts without too many corners and edges. However, the entrance area is inconvenient: quite narrow and without natural light. He definitely needs to revise that. I have a meeting with him tomorrow, so let’s see what the second draft will look like. I’ll share it with you then. Thanks for your effort.
16 Nov 2025 23:49
lucaskilam schrieb:
What I like most about the floor plan created by the architect is that the living and dining areas are designed as one large, open space.
Well, that was the first thing I pointed out.
When I looked at the design last night, I immediately thought there is a missing wall right where the three chairs are, which would give the space more structure.
For me, besides everyday functionality, it is important that the house looks very appealing from the outside. Natural light is part of the functionality.
lucaskilam
27 Nov 2025 11:19
I have a question regarding neighbor approval. The design extends further to the rear and is higher in the living area than the neighbor’s existing building.
Our questions are as follows:
  • Is neighbor approval definitely required if we want to build exactly according to this design?
  • What happens if the neighbor does not agree? Will the application be automatically rejected, or does the authority review whether approval is actually necessary?
  • Would we have to completely change the design, or can the authority approve it without approval if no neighbor protection rights are affected?
We already had a conversation with the neighbor. Verbally, they had no objections. However, when I asked for written confirmation, they suddenly said they want to speak with the authority first. An appointment there likely won’t take place this year anymore.
So my question is: Should we still submit the building permit / planning permission application to avoid losing time? Our original plan was to include the neighbor’s approval in the application to avoid potential additional requests.
I appreciate any experiences and insights on how authorities usually handle such cases and how strictly neighbor approval is enforced in practice.
Thank you
kbt09
27 Nov 2025 11:24
Is there a final building plan available now?
lucaskilam
27 Nov 2025 11:40
kbt09 schrieb:
Is there already a final building plan?
No, there are no changes to the exterior appearance. The architect is currently revising only the floor plan and the interior layout.
