ᐅ Old basement from 1910 with water drainage shaft
Created on: 20 Sep 2025 20:07
walkers
We have purchased a house built in 1910.
The basement is completely dry, which is already a positive sign.
In the basement, there is this opening, fully tiled except for a 2 cm (1 inch) gap where a gravel bed is located. The water inside is also very clear. What could this be? According to the seller, the water has always been used for irrigating the garden. I’m concerned that it might overflow since there is no pump or similar system installed.
The building is situated on a slope, and one side is only 0.5 m (20 inches) below ground level. It should therefore be considered a high basement.
Dunkler Ofen mit bogenförmiger Öffnung und Fliesenboden im Küchenbereich.
HausiKlausi21 Sep 2025 22:43
walkers schrieb:
However, I myself do not know where the yellow corrugated pipe comes from, and neither does the seller.
Or could it be that the house has drainage at the sides, which is directed into the basement at the lowest point? This would make sense if it leads into the house opposite the hillside side.
21 Sep 2025 23:35
walkers schrieb:
In the basement, there is this opening, which is fully tiled except for a 2 cm (0.8 inch) gap filled with gravel. The water inside is also very clear. What could this be? According to the seller, the water was always used for garden irrigation. I am just concerned that it might overflow since there is no pump or anything installed.
The building is located on a slope, and one side is only 0.5 m (1.6 feet) below ground level. So, it should be a raised basement.
[IMG width="500px" alt="Dark stove with arched opening and tiled floor in kitchen area."]https://www.hausbau-forum.de/attachments/ofen-im-kuechenbereich-mit-fliesen-jpg.92948/[/IMG]
Explain this photo to me, if it looks different 😉
It is a sump pit. Why it was built doesn’t really matter, as long as the sump does what it’s supposed to, which is to drain water.
I had one myself under my basement, but mine had a pump and was covered. The water there was soapy; I wouldn’t have wanted to use it.
walkers
22 Sep 2025 11:58
HausiKlausi schrieb:
Or could it be that the house has drainage on the sides
I will look into this again today.
It has rained a lot in the last few hours, so something must have changed.
The neighbors’ houses do not have this.
walkers
22 Sep 2025 16:23
The water was soapy; I wouldn’t have wanted to use it.
The water here is not soapy. It is completely clear. It has been raining continuously here since last night, and the water level has remained the same.
