ᐅ Floor Plan Feedback Single-Family Home 140 sqm Two Full Stories
Created on: 4 Jul 2025 16:06
Milka0105
Hello everyone, following my last post about costs and so on, Ant11 suggested that I start with a floor plan here for evaluation. This plan has now existed for quite some time with a few minor adjustments, so the ideas have not changed. I’m looking forward to some feedback.
Plot size 654 sqm (7040 sq ft)
Slope no
Site occupancy index 0.4
Floor area ratio 0.8
Building setback, building line and boundary 3 m (10 ft)
Edge development only garages or carport
Number of parking spaces 2
Number of floors max 2
Roof pitch 0–48 degrees
Style single-family house
Orientation any
Maximum heights / limits 6 m (20 ft) wall and 9 m (30 ft) total
Other requirements cistern
Style, roof type, building type gable roof
Basement, floors 2
Number of people, age 2 adults and potentially 2 children, currently 1
Space requirements ground floor, upper floor
Office: family use or home office? Both
Guest sleeping per year, if so guests sleep in the children’s rooms
Open kitchen, kitchen island open kitchen
Number of dining seats 1
Fireplace no
Music / stereo wall no
Balcony, roof terrace no
Garage, carport yes
Utility garden, greenhouse possible
Other wishes / special features / daily routine, also reasons why this or that should or should not be included
Who designed it:
- Initial draft by architect then adjustments with builder/architect
What do you particularly like? Why? Utility room with separate door (mudroom), large pantry
What do you dislike? Why?
Price estimate according to architect/planner: 433k
Personal price limit for the house, including fixtures: 500k
Preferred heating technology: air heat pump and central ventilation system
If you had to give up, which details / extensions
- Could you give up: if push comes to shove, the separate door for the utility room or the pantry could be omitted
- Could you not give up: guest WC with shower
Why did the design turn out the way it did? For example:
Build as small as possible but as large as necessary. The plot becomes wider toward the back.
So, this is a draft after a consultation appointment with the architect. It was then revised again with the builder.
We want a functional home that works for 2 adults and potentially 2 children (1 currently). In addition, we have a dog, but that obviously adapts too (the mudroom is also designed for this).
Home office is generally possible and planned. First, we have one child’s room reserved and intended for this purpose. Afterwards, the office niche or the bedroom upstairs. We don’t need much except a quiet place to work.
If all else fails, the pantry will become the office (possibly then accessible from the hallway).
The upstairs bathroom is somewhat elongated due to the narrow building footprint and straight staircase. The washing machine and dryer are shown upstairs and are planned to be there. There are also connections in the utility room. Otherwise, the space upstairs or downstairs will be used for storage.
I look forward to your opinions.
Slope no
Orientation any
Basement, floors 2
Fireplace no
Garage, carport yes
Who designed it:
I don’t see any technical room at all, just a secondary entrance.
For stairs, I would always try to plan a tread depth of 26 to 27 cm (10 to 11 inches).
And my question again would be: why such a huge carport and garage? How is their intended use?
The southeast side, which gets the most sun especially in winter, is therefore pushed to 3 m (10 feet) towards the neighboring property on the left side of the plan. What is planned for the adjacent lot there?
Milka01058 Jul 2025 10:46wiltshire schrieb:
I can’t assess this without seeing the upper floor. Yes, I’m working on it right now. The staircase needs to be rotated. It doesn’t work at all as it is upstairs. I will add it then.
Milka01058 Jul 2025 10:47kbt09 schrieb:
I don’t see a utility room at all, only a side entrance. The utility room is now located in the middle on the ground floor. Sorry, the label is missing. The side entrance is now the main entrance.
Milka01058 Jul 2025 10:50kbt09 schrieb:
I don’t see any technical room at all, only a side entrance.
I would always try to plan stairs with a tread depth of 26 to 27 cm (10 to 10.6 inches).
And my question again: why such a huge carport and garage? How is the intended use?
The southeast side, which gets the most sun especially in winter, is pushed to 3 m (10 feet) next to the neighboring property on the left side of the plan. What is planned there on the adjacent lot? Next to it there is a double garage directly on the boundary. The carport is meant for parking the car, storing bicycles, garbage bins, etc. Besides the car, it should also be possible to walk through to the garden. The plan includes a car width of 3.5 m (11.5 feet) and then a 2.5 m (8 feet) wide space for exiting the door and passing through or moving around.
Milka01058 Jul 2025 11:32wiltshire schrieb:
I can’t assess this without seeing the upper floor.Here is the upper floor. I can no longer edit the other post.
