ᐅ Is a staircase required to comply with DIN 18065 or not?
Created on: 16 Nov 2024 01:29
Timotheus
Hi,
we are currently in the planning phase for our small wooden house.
Our architect wants to design our staircase according to standard 18065, but this does not match our size preferences.
We want a straight staircase with a length of 250cm (98 inches)... according to the standard, we would have to extend it to at least 290cm (114 inches). The width of 100cm (39 inches) remains unchanged.
Now to our question: Does a staircase in Lower Saxony have to be designed/built according to standard 18065?
In the technical building regulations, I found this paragraph.
Regarding DIN 18065
  • 1.
  • The introduction excludes the application to staircases in residential buildings of building classes 1 and 2 and in apartments.
I could not find a clear answer as to whether I have to comply with the standard.
Timotheus
19 Nov 2024 17:46
kbt09 schrieb:
I agree with @ypg, a tread depth of 23.26 cm instead of the 26.5 cm from my example, that’s more than a 3 cm difference.
And I thought the staircase length was limited to 250 cm. Here, 305 cm is planned.
The 250 cm limit cannot be met according to the standard. We acknowledged this and therefore extended the wall to 305 cm (120 inches).
We tested stairs with tread depths between 23 and 30 cm (9 and 12 inches). As long as the stairs do not have risers, this is completely fine for us (even at an older age).
11ant19 Nov 2024 17:51
Timotheus schrieb:
We have planned it as shown in the picture.
Although I appreciate the reasonable ceiling thickness, there is certainly still potential for reduction in the clear height of 278cm (109.5 inches).
Timotheus schrieb:
As long as the staircase has no risers, this is completely fine for us (even in old age).
However, where stair use becomes painful even for young people due to injuries, this mainly concerns going downstairs.
Timotheus
19 Nov 2024 17:51
Schorsch_baut schrieb:
And in my opinion, that is the wrong assumption—or a situation that can be compensated for with better planning.
It's like wearing shoes that are one size too small.
Could you please explain your statement in more detail?
We have planned a small house and would like to keep our room layout if possible.
You are all right that compliance with the DIN standards should be considered in many aspects. But isn’t it acceptable to find a good compromise in such cases?
Timotheus
19 Nov 2024 17:53
Even though I’m impressed by the reasonable ceiling thickness, there’s definitely still potential to reduce the clear height of 278cm (109 inches).
We thought the same, but unfortunately, you have to subtract the 20cm (8 inches) ceiling joists again. That brings us down to 258cm (102 inches).
11ant19 Nov 2024 18:02
Timotheus schrieb:
We thought so too, but unfortunately you still have to subtract the 20cm (8 inches) ceiling joists. That leaves us with 258cm (102 inches).
Everything has already been deducted for the clear height. If you enter incorrect values into the stair calculator, you will get nonsense results.
Which room layout do you want to "keep"? If the layout was based on incorrect assumptions, the calculation won’t work and the option to "keep" it is void.
As far as I remember, we still don’t know what the plan actually is here. Are you trying to downsize a catalog model?
19 Nov 2024 18:26
Timotheus schrieb:
As I said... other staircases are probably more comfortable to walk on.
But I prefer having 60–70cm (24–28 inches) more living space if it meets the DIN standards.
What good are the extra 60/70cm (24/28 inches) if you have to put a bed of about 2sqm (22 sqft), like your neighbors, on the ground floor or use the couch? A proper bathroom is probably not available on the ground floor either—you will have to rely on the upper floor in a small house.
Timotheus schrieb:
We have planned a small house and want to keep our room layout if possible.
Then show it. Maybe you can get advice on a good arrangement so that it doesn’t matter so much?! Many houses are designed with unnecessary clutter, awkward corners, and wasted space. Often, some adjustments are possible.
Timotheus schrieb:
That is completely fine for us. (also as we get older)
None of us can really know beforehand how difficult it often gets, even if we’re healthy. My husband now slowly shuffles up the stairs with stops due to health reasons; I myself value the stairs less after a foot surgery and several ligament strains. For the past year, a dog has been constantly underfoot... many neighbors now have hip or knee issues. The only advantage is probably that climbing up a steep staircase is easier.
