we have recently purchased a plot of land and plan to build a house on it in the next few years.
I have been thinking a lot about the floor plan and the size—just roughly speaking. We recently visited a show home from a local company specializing in solid construction, which is very affordable and also appealed to us.
I am quite certain that we will not go through an architect but will look for promotion houses from companies instead, mainly to save costs. Of course, compromises are necessary, but we don’t have any extraordinary requirements at the moment.
Therefore, I wanted to ask more generally if anyone has experience building promotion houses regardless of the company. Were there any unexpected costs, or did the predefined floor plans turn out to be less practical than expected?
Enrico02 schrieb:
Sun exposure, neighboring buildings, views, optimal terrace location, etc.) hanse987 schrieb:
I usually find it more difficult to tell if a standard house design fits the existing plot. Often it fits, sometimes it doesn’t.
roteweste schrieb:
So the main entrance would be on the south side and the terrace on the north, or what’s the plan? In my opinion, it doesn’t look like a standard template. I would consult an architect. That doesn’t have to be the case. You can orient the entrance towards the driveway, depending on the floor plan of the model house.
And if someone values the cost certainty of a general contractor, there is always the usual standard model house, which can usually be modified without extra costs.
There are quite a few options that also align well with the plot orientation.
Enrico02 schrieb:
Of course, additional costs always occur. The best way is to review and compare the individual specifications of building services. Exactly. These are not called hidden costs—they just happen.
Before you start thinking about a model house, you should first consider and inform yourself about the basics. Otherwise, you start the building process at the far end of the spectrum.
That means: setting your budget, calculating additional construction-related costs, then estimating the house size based on your wishes using a price of 3000 €/m² (279 sq ft).
Solid construction or prefabricated house, which companies operate regionally. Regional providers are often cheaper than large, nationwide firms.
If you finally decide on a prefabricated house from a nationwide company, but the price is unaffordable or tight, you could consider a model house as plan B.
A regional solid house, meaning a proven standard design, is usually cheaper, but these are not promoted as model homes since nothing is prefabricated.
Additional custom features always add significant costs on top of the catalog price—even if it’s just a few extra power outlets.
And if you use the forum search, you can see who might have already built a model house here.
That immediately raises a lot of questions for me:
Access via the "field path" is probably not possible, so it will be necessary to use the street. However, if the plot is 2 meters (6.5 feet) higher, you should definitely consider how to solve this. I would take a look at how the neighbors have handled this issue. Then you probably have a north-facing garden. Unless, of course, you place the house at the back of the plot, if permitted. In that case, it would also be possible to manage the 2-meter (6.5-foot) elevation difference with a long driveway. But that is also anything but cheap, of course.
To me, this does not sound like an easy plot to build on.
Hausbau20250016 Oct 2024 15:20Yes, that’s what we had in mind.
roteweste schrieb:
So the front door would be more towards the south and the terrace to the north, or is that the plan? In my opinion, it definitely doesn’t look like a standard layout. I would consult an architect.
Hausbau20250016 Oct 2024 15:21Aloha_Lars schrieb:
The much more important question is whether you are even allowed to build the ready-made house according to the zoning plan. If you are not allowed, you will have serious problems.We do not have a zoning plan, so we base it on the neighboring houses, which are all standard single-family homes and the type we want as well.H
Hausbau20250016 Oct 2024 15:25Enrico02 schrieb:
This immediately raises a lot of questions for me:
Access via the "dirt track" is probably not feasible, so access from the road is necessary. However, if the plot is 2m (6.5 feet) higher, you should consider how to manage this. I would take a look at how the neighbors have solved this issue. Then you'd likely have a north-facing garden. Of course, you could also place the house at the back of the plot, if allowed. That would make it possible to use a long driveway to handle the 2-meter (6.5 feet) elevation difference, though that would be anything but inexpensive.
To me, this doesn’t sound like a straightforward plot choice. Exactly, the access is planned from the street. The two houses next door have basements with driveways that are essentially level, and the garages are at basement level. We don’t want that. Would it be such a problem if the driveway was a bit steeper, or if it were made longer to reduce the incline?
Hausbau20250016 Oct 2024 15:31ypg schrieb:
Sometimes it fits, sometimes it doesn’t.
It doesn’t have to. You can rotate the driveway entrance depending on the floor plan of the special offer house.
And if someone values the cost certainty of a general contractor, there is still the standard model home, which can usually be modified without extra costs.
And there are several options that also align with the orientation of the plot.
Exactly. They’re not called hidden costs; they just occur.
Before you consider a special offer house, you should first think about and inform yourself on the basics. Otherwise, you start building at the end of the process.
That means: setting your budget, calculating additional construction costs, then estimating your desired house size at 3000 €/m² (279 sq ft).
Solid construction or prefab, which companies are available regionally. Regional providers are often cheaper than large nationwide companies.
If mentally you decide on a prefab house from a nationwide provider but the price is too high or tight, then Plan B could be to choose a special offer house.
Usually, a regional solid construction house, meaning a proven model home, is cheaper—these aren’t promotional offers since nothing is prefabricated.
On top of the catalog price, upgrade requests always add expenses—even if it’s just a few extra power outlets.
And if you use the forum’s search function, you can often find out who here may have built a special offer house. The regional company we contacted has its own series of different house sizes where the price per square meter is about 2000 € (186 sq ft). This is of course very affordable, but because these floor plans are predefined.
