ᐅ Where is the roller shutter box located, and where am I allowed to drill?
Created on: 10 Sep 2024 09:18
Hafenguy
Hafenguy
10 Sep 2024 09:18
Hi everyone,
We would like to install curtains, but all the rooms already have roller blinds.
Does anyone know how far the roller blind boxes extend? We would prefer not to drill in the wrong place.
The strap is already mounted a bit away from the window, so I would guess that the boxes are located at the strap position and then nothing beyond that.
Open window with a view of a green tree outside; bright interior.
F
FloHB123
10 Sep 2024 10:03
Tap on the box. You can usually hear clearly where the box ends.
Jesse Custer
10 Sep 2024 13:18
Based on the same issue, we screwed the rods/strips to the ceiling and used corresponding spacer bars to adjust the height accordingly...
This also makes more structural sense...
F
FloHB123
10 Sep 2024 13:26
You are right about that. However, the right wall is angled, and the curtain might not fully cover the window in that case.
I would simply check exactly where the box ends and drill there.
Alternatively: Open the box and measure.
11ant10 Sep 2024 13:31
FloHB123 schrieb:
Try knocking on the box. You can usually hear quite well where the box ends.
I suspect there is no visible end of the box here at all.
FloHB123 schrieb:
You are right about that. However, the right wall is slanted and the curtain probably wouldn’t fully cover the window then.
Then you didn’t understand the good advice:
Jesse Custer schrieb:
Based on the same issue, we screwed the rods / rails to the ceiling and used spacer bars accordingly, so the height would be just right.
