ᐅ Difference Between a Dimmer Switch and a Dimmer Push Button?
Created on: 27 Aug 2024 12:59
bwollowb
bwollowb
27 Aug 2024 12:59
Hello, unfortunately, I’m not very skilled with electrical matters. So please forgive me if this question seems silly. I understand the difference between a switch and a push button. But if both have a dimming function, is there still a difference? Important: I’m not asking about the electrical wiring or the technical details behind it, but purely about the appearance of the switch/push button!
Thanks for your helpful answers!
DeepRed27 Aug 2024 15:16
Dimmers are usually round rotary knobs that turn the light on at the brightness level it was set to when switched off by pressing the center. Turning the knob left or right adjusts the brightness dimmer or brighter.
Dimmer switches look like regular push-button light switches. The first press turns the light on at the brightness level it was before turning off. Holding the button increases the brightness, releasing and pressing again dims the light.
I’m not an electrician either, but this is how it works for me. Dining table lamps use dimmer knobs, LED bathroom lighting uses push-button dimmers.
bwollowb
27 Aug 2024 15:53
DeepRed schrieb:
Dining table lamps with rotary dimmers, LED bathroom lighting with push-button dimmers.
Thank you for your explanation! I have gained a better understanding of the topic now. The difference really is between rotary dimmers and push-button dimmers. Are there any reasons to install one type in one room and the other type in a different room?
nordanney
27 Aug 2024 17:16
bwollowb schrieb:
Are there reasons why one type is installed in one room and another type in a different room?
- different aesthetic requirements
- availability
etc.
11ant27 Aug 2024 18:04
bwollowb schrieb:
I understand the difference between a switch and a push button. But if both have a dimming function, is there still any difference? Note: I’m not asking about the electrical side or the wiring behind it, but purely about the appearance of the switch/push button!
I assume you can get a dimming push button designed to look like blinds up/down push buttons. What is your intended application?
bwollowb
27 Aug 2024 20:08
What is your application?
In this case, the application is solely lighting (ceiling lights). Hence the question whether there are any recommendations for individual rooms on whether rotary dimmers or push-button dimmers are better.
