ᐅ LED recessed downlights for 60mm ceiling outlet box
Created on: 3 Jun 2024 21:17
Hansi H.
Hansi H.
3 Jun 2024 21:17
Hello everyone!
During our house planning, we thought about skipping the installation of extra halogen sockets (which would have been quite expensive with our provider) and instead using surface-mounted spotlights.
However, I have now realized that with LED spots, there are models available that should fit into 60mm (2.4 inches) flush-mounted boxes.
Has anyone done this or found suitable ones? Basically, I am looking for white, adjustable spotlights with 2700K.
Thanks and best regards!
nordanney
3 Jun 2024 21:52
Hansi H. schrieb:
that should fit into 60mm (2.4 inches) outlet boxes.
Where does that measurement come from? Who does something like that and why?
Hansi H. schrieb:
Has anyone made or found suitable ones? I would generally look for white, adjustable ones with 2700K.
I’m too lazy right now to paste the first 1,867 results here when I search for LED spots with a 60mm (2.4 inches) cutout size. The internet is full of them.
Gerddieter
3 Jun 2024 22:40
Don’t think that will work... either they still need a transformer and so on – but where would that go? Or without a transformer, GU10 type bulbs – but there isn’t enough depth for those....
Just use surface-mounted spotlights....
Gerddieter
nordanney
3 Jun 2024 22:57
Gerddieter schrieb:
I don’t think that will work... either they still need a transformer or something – where would those go?
Standard 230 volts – I would only use ones without a transformer anyway. They also come in a flat version – they only require 35mm (1.4 inches) height and can be easily tilted. This is pretty standard nowadays.
Hansi H.
4 Jun 2024 07:23
nordanney schrieb:
How do you come up with such a dimension? Who does something like that and why?
I'm too lazy to include the first 1,867 results here when searching for LED spots with a 60mm (2.4 inches) hole size. The internet is full of them.
Because that is the size of a standard ceiling outlet box, and everyone installs that in a concrete ceiling. Exactly: 1867 doesn’t necessarily mean they are high quality or that it works well. I was asking for a recommendation.
nordanney
4 Jun 2024 07:29
Hansi H. schrieb:
The size of a standard ceiling outlet box is
No, it isn’t. But okay.
Hansi H. schrieb:
Exactly: 1867 definitely doesn’t mean they are high-quality or that they work well.
What does "high-quality" mean to you? I’ve installed so many of these spotlights costing from €5 (around $5.50) each, some direct imports from China and some branded products. So far, I haven’t noticed any real difference. Just pick something that looks good (with the right beam angle and desired light color, etc.) – if they’re very affordable, maybe buy a few as spares and enjoy the lighting.
You really can’t give a recommendation here. It’s like saying, "I’m looking for a red car – give me a recommendation!"
