ᐅ Is it possible to combine district heating or local heating with an air heating system? New build
Created on: 18 May 2024 10:53
ArmbrustDear Forum,
I have some questions regarding the possible heating options I could have.
In our new development, there is a mandatory connection to a local low-temperature district heating network. This network is a geothermal system with probes and operates at 20°C (68°F). At the house connection point, 20°C (68°F) water is supplied. There is a heat pump (currently owned by the network operator) that heats the water to the desired temperature and then transfers it either to a hot water storage tank or directly into the heating circuit.
Key details about the planned house:
- 150m² (1,615 sq ft) living area
- KfW40 energy standard
1. Naturally, I can heat well with underfloor heating using this system, right?
2. I would prefer to use a ventilation system with heat recovery and also heat via that system. Can I use this system for heating? Is it even common for the heat exchangers in the ventilation system to be water-to-air heat exchangers?
2a. There is an additional option for “tempering,” so I could also cool through this system, correct?
Yes, this district heating network and contract are really restrictive, and the connection cost of €27,000 seems excessive to me, but I would prefer not to discuss this topic here.
Rübe1 schrieb:
1. yes
2. No. For the rest, you would need to know,
a) what kind of device?
b) does the utility provider even allow that? (keyword: additional heat sources) Thank you,
Why would it be necessary to know what kind of device it is?
I have a heat pump that produces hot water; this is owned by the utility provider, so I have no influence over it.
However, I could choose the ventilation system myself. There should be ventilation systems that use heat from the water to warm the air, right?
Or where is my misunderstanding?
hanse987 schrieb:
Why do you want to heat with or through the ventilation system at all?- no radiators
- no expensive underfloor heating
- pollen-filtered fresh air
- air doesn't enter the house cold
nordanney18 May 2024 14:17Armbrust schrieb:
On the other hand, I could choose the ventilation system myself. A ventilation system that uses heat from water to warm the air should exist, right? No, such a system does not actually exist. These are two completely different things – one is a VENTILATION system, the other is a HEATING system. A ventilation system only circulates a small amount of air, so it is practically impossible to use it for heating.
