ᐅ The wall creaks and groans when the interior door is opened.
Created on: 2 Mar 2024 12:12
trksglm
trksglm
2 Mar 2024 12:12
we built our house 4 years ago (2020) and moved in.
One of the room doors creaks briefly when opened. All other doors are quiet, as expected.
It can’t be the door frame because it has already been aligned and oiled. We suspect the issue lies in the connection between the drywall (plasterboard) wall, the door frame, and the PVC flooring.
But pinpointing the problem? That’s the tricky part! We are getting frustrated because even after a second attempt, the professionals couldn’t fully fix the issue. Pictures will follow.
Maybe this community has some solutions?
Thank you.
Best regards, Tarik
Close-up of a white door frame with damaged edge and visible wooden core.
Close-up of the bottom edge of a white piece of furniture on a light gray wooden floor, scratches visible.
Close-up of a silver door hinge on a white door.
Close-up of the door threshold with sealing strip, gray foam, wooden and concrete frame visible.
Door passage in renovation condition: open gap, insulation material and laminate floor visible.
11ant2 Mar 2024 14:40
trksglm schrieb:
We built our house 4 years ago (2020) and moved in new.
One of the doors to a room squeaks briefly when opened. All other doors are quiet and are as expected.
It can’t be the door frame, since it has already been aligned and oiled. The issue seems to be related to the connection between the drywall, door frame, and PVC flooring.
But this is a "where’s the fault?" situation?! We are really frustrated because even the experts couldn’t fully resolve the root cause after a second attempt.
Who were these “experts” – installers from the construction company...
trksglm schrieb:
Our builder glued the vapor barrier on the ceiling to the wall. The joints don’t look very neat to us,
… who apparently already back then didn’t inspire much confidence?
It seems to me that there are various issues with shape, fit, and alignment that aren’t quite right; besides the last attempt, oiling won’t help much. Door frames standing on the floor (even with a gap) probably aren’t exactly top quality either. I hope the warranty period hasn’t expired or been interrupted. Under warranty, the contractor has the right to repair defects, but that does not mean you should let the contractor judge whether a fault exists instead of involving an independent expert. Discuss this with a specialist lawyer and consider hiring a professional surveyor.
nordanney
2 Mar 2024 14:59
trksglm schrieb:
Maybe there are solutions within the community here?
Just leave the door open. A simple and straightforward solution.
2 Mar 2024 23:46
trksglm schrieb:
there must be a connection between the drywall, door frame, and PVC covering.
It is likely that the metal studs of the drywall are stressed.
In our case, half of the attic is affected: when we moved in 2014 and the storms got stronger, it felt like the entire upper floor creaked. We had the choice: file a complaint and have everything opened up or live with the creaking during storms. We chose the latter.
trksglm schrieb:
We are at our wits’ end,
We are not. Why get so upset about brief creaking? It shouldn’t be necessary. I would try to relax a bit.
Benutzer 1001
3 Mar 2024 08:28
Built in 2020? Then contact the company; they need to provide a solution here.
trksglm
3 Mar 2024 08:53
It is likely that the metal frame of the drywall, meaning the studs, are under stress.
In our case, it affects half of the attic: when we moved in in 2014 and the storms became stronger, it felt like the entire upper floor was creaking. We had the choice to file a defect report and have everything opened up or to live with the creaking during storms. We chose the latter.
But we didn’t. Why despair over a brief creak? It doesn’t have to be that way. I would try to relax about it.
Thank you for the responses.
A brief creak in a new build is a no-go. Over time you do get used to the creaking and would be more surprised if it eventually stopped 😉
