ᐅ Sloped recess in the foundation slab for a walk-in (curbless) shower
Created on: 6 Dec 2023 15:59
Ralf1980Hello.
While visiting some shell construction sites recently, I noticed the structure shown in the attached pictures.
A sloping recess about 20cm (8 inches) wide was included in the concrete slab, extending all the way to the precast concrete ceiling.
Of course, this is not my project, and theoretically it’s none of my business, but I’m curious if anyone has seen something like this before, and what kind of shower design would require such a construction, in case I ever need it myself…
The screed has not yet been installed, only the precast ceiling and the concrete above it. The interior and exterior walls have been built with masonry.
Best regards and thanks!
WilderSueden6 Dec 2023 22:46I have some doubts about whether it’s acceptable for the reinforcement to be visible. It also looks more like a mezzanine floor than a slab foundation. Ideally, for the slab foundation, a PVC drain pipe should be laid in the correct position below the slab. In the upper floor, our tiler installed it within the sloped screed.
WilderSueden schrieb:
It looks more like an intermediate ceiling than a concrete slab to me. That’s what I assumed, since the first post also mentioned a prefabricated hollow-core slab.
X
xMisterDx7 Dec 2023 09:17Where should the problem be if you can see the reinforcement and it is intact? At the moment, no one knows whether this was planned that way, meaning whether the mesh was cut and installed accordingly, or if the concrete contractor did it on their own initiative.
Basically, making an opening in the reinforced concrete slab is possible; otherwise, there would be no stairs...
