ᐅ Which Tiles Are Best for a Workshop? Recommendations and Tips?
Created on: 14 Aug 2023 23:15
HoisleBauer22
HoisleBauer22
14 Aug 2023 23:15
For the workshop in the basement (with underfloor heating), I am looking for tiles. What should I pay attention to? Which tiles have you had good experiences with? What tile size and pattern did you choose? So many questions...
hanse987
14 Aug 2023 23:32
What work is going to be done in the workshop?
X
xMisterDx
14 Aug 2023 23:51
The pattern doesn’t really matter for the workshop, does it? That’s a design choice. For a workshop, choose what produces the least waste and is the easiest to install.
They need to be durable in case you drop the 32mm (1 1/4 inch) wrench and non-slip in case the beer mug... uh, the oil can tips over.
And here’s the tip again: if perfection isn’t the priority, do it yourself. If someone sets up a “workshop” in their house, laying tiles shouldn’t be a problem for them...
11ant15 Aug 2023 11:30
hanse987 schrieb:
What is supposed to be done in the workshop?
Probably an excuse made up, see the original thread:
https://www.hausbau-forum.de/threads/dieselben-fliesen-im-ganzen-eg-und-im-bad-auch-im-keller-gleich.45924/page-6#post-638185
sysrun80
15 Aug 2023 14:06
As long as you don’t plan to break game there, avoid using tiles. All it takes is for a tool to slip from your hand once, and you'll end up with a chip.
HoisleBauer22
15 Aug 2023 18:22
sysrun80 schrieb:
don’t use tiles.
Alternative? What did you choose?
I’m a bit annoyed that there isn’t a standard or value for “hardness” like the Brinell hardness for wood that also applies to tiles...
