ᐅ Floor plan design for a single-family house, 165 sqm, without a basement, on a 400 sqm plot
Created on: 10 Aug 2023 09:33
Maulwurfbau
At the request of 11ant, here is a post with the completed list ;-) Unfortunately, he still doesn’t have a crystal ball.
Providing all information possible/available at this point in time.
Plot size: 400 sqm (4300 sq ft)
Slope: No, and no means no!
Floor space index (FSI): 0.4
Floor area ratio (FAR): ?
Building envelope, building line and boundary: Yes, available.
Edge development: Possible with garage.
Number of parking spaces: at least 1, preferably 2
Number of storeys: 1-2
Roof type: Gable roof (pitch minimum 31°, maximum 45°)
Architectural style: ??
Orientation: Gable end facing
Maximum heights / limits: Roof ridge 6-7 m (20-23 ft), eaves 9-12 m (30-39 ft)
Other requirements: No brick facades allowed. Driveway or space in front of garage at least 6 m (20 ft). Red roof tiles mandatory, light facade.
Homeowners’ Requirements
Architectural style, roof type, building type: Gable roof, fixed
Basement, storeys: 2 full storeys without basement
Number of occupants, age: 4 people (2 toddlers)
Space requirements on ground floor and upper floor:
Office: Family use or home office? Office of approx. 12 sqm (130 sq ft) is a must.
Guest bedrooms per year: Few
Open or closed architecture: ? Whatever that means.
Conservative or modern construction style: rather modern construction.
Open kitchen, cooking island: Open kitchen, possibly with cooking island
Number of dining seats: 6
Fireplace: NO
Music / stereo wall: Not planned, TV location is quite important.
Balcony, roof terrace: NO
Garage, carport: Garage desired. Carport with storage box also conceivable.
Utility garden, greenhouse: NO
Further wishes / special features / daily routine, preferably with reasons for choices:
Laundry room on the upper floor. They want to do laundry where it is generated and where it must be returned clean. Anything else is a hassle, at least for us.
Who designed the plan: Architect
Everything we provided as basic information and what our daily life requires has been implemented.
We like the clear lines/structure.
The open space in the hallway.
The connection/proximity of all rooms on ground and upper floors that need water/sewage. So no funny business with the bathroom upstairs in one corner and the utility room diagonally opposite on the ground floor. Personally, I like that.
No bay windows or other awkward extensions.
Laundry room upstairs where the washer and dryer are planned.
What don’t you like? Why?
The living room might be a bit too exposed for us. It could also be a cozy nook with TV without direct view of the kitchen. Cooking and eating together openly is liked; the living room could be a bit more separate. Currently, the floor plan shows it like a narrow, rather shadowy corner.
The somewhat narrow bedroom upstairs is not a dealbreaker but not 100% pleasing.
Personal price limit for the house, including fixtures and fittings:
500-575k
Preferred heating system:
Predefined, ground source heat pump with collector. Cold local heating network.
If you have to give up, which details/extras
-can you do without:
The small additional room for the father upstairs.
Garage, as mentioned carport also conceivable.
-can you not do without:
Office.
Storage box at garage or carport.
Children’s rooms.
The design turned out this way because the architect implemented our wishes and requirements almost 1:1. This preliminary layout resulted in this first version.
What do you consider particularly good or bad?
See what we like and what not. We don’t find anything particularly bad. Rather, not entirely optimal.
Position garage flush with house or set back?
43.5 sqm (468 sq ft) + 4 sqm (43 sq ft) pantry sufficient as “all-purpose room”?
Same floor plan possibly mirrored? Then office on south side, sun all day, blinds always down. Same issue upstairs with bedroom in summer at least. Entrance farther from parking space.
The building method will be timber frame construction with a local timber builder.
This is a first sketch after clarifying needs/wishes with the architect.
Fireplace: NO
500-575k
Office.
Children’s rooms.
If the open living area has improved but not the hallway, it might be because the main entrance is located on the short gable side of the house. I already mentioned that the entrance “belongs” where the utility room is located in posts #51 / #52 – and that this effectively resolves the garage placement question; "no alternative," as the former Chancellor used to say.
Maulwurfbau12 Aug 2023 20:26Yes, that could really work well. It would also be convenient for me; a roofed entrance area next to the garage would not be a bad thing either.
However, I heard somewhere that with timber frame construction, there needs to be a step in front of the entrance. Because of that, the garage door shouldn't be too close to the house, due to the step you would have to drive over. This is apparently related to the fact that the house is not continuously supported on a beam that should preferably not be underground, to avoid moisture issues.
Is that correct? Is a ground-level entrance not possible for a prefabricated house?
Maulwurfbau schrieb:
Is that true? Is a single-story prefabricated house not built at ground level? No idea. The concrete slab is just like in a brick house. Even solid construction is best built slightly above street level...
However, I would personally always plan a small entrance area in front of the main door. You don’t want to be standing in the driveway lane when unlocking the door, right? And you also need somewhere to place a welcome flower pot. Sorry, but no entrance looks right without some decoration. 😀
Maulwurfbau13 Aug 2023 07:21ypg schrieb:
No idea. The foundation slab is made of concrete just like with a brick house. Even solid construction is best built above street level…
However, I would personally always plan a small entrance area in front of the front door. You don’t want to stand in the driveway when unlocking the front door, right?! And you also want to have a place for a welcome flowerpot somewhere. Sorry, but no entrance looks good without some decoration 😀 Yes, exactly. A small platform as an entrance, and if the garage door is too close to the house, the platform might overlap with the garage door in the worst case—I hope you know what I mean.
The construction company also said that your house always requires such a platform or step at the entrance because the beam on the foundation slab must always be positioned above it.
A small platform as an entrance, and if the garage door is positioned too close to the house, in the worst case the platform overlaps with the garage door, [...] And the construction company said that your house will always require such a platform or step as an entrance, because the beam on the foundation slab must always be positioned above ground level. Well, those are some real jokers. They create more side setback to gain more driveway width because of the platform, even though the entrance is on the gable side.
