ᐅ The plaster has come loose around the channels cut for wiring.
Created on: 18 Jul 2023 23:05
Hunsrückblick
Hunsrückblick18 Jul 2023 23:05
Hello, I visited my construction site today full of anticipation, but since then I have been a bit concerned.
What could be the reason for the plaster detaching from the wall? It surely can’t be caused by the chasing alone, right?
Exposed red brick wall with two insulated water pipes (hot/cold) mounted on a bracket.
sysrun80
18 Jul 2023 23:10
Sorry, but it didn’t “come loose” and fall off the wall with the clean “diagonals.” In the upper area, you can even see marks on the plaster...
Hunsrückblick18 Jul 2023 23:13
sysrun80 schrieb:
Sorry, but it didn’t just “come loose” and fall off the wall along the clean “diagonals.” You can even see marks on the plaster in the upper area...
The installer chipped away at the plaster a bit to check if it was secure. The marks are from the hammer!!! The material fell off over a large area!!!!
sysrun80
18 Jul 2023 23:19
Hunsrückblick schrieb:
The installer tapped the plaster to check if it was solid. The marks are from a hammer!!! Large areas of the material have come off!!!!
Really?! 🤨 Oh no... What type of plaster is that?
Hunsrückblick18 Jul 2023 23:20
These panels fell off the wall in one piece.
A hand holding a white panel fragment with vertical grooves in front of a brick wall with pipes.
Hunsrückblick18 Jul 2023 23:24
sysrun80 schrieb:
Really?! 🤨 Wow... What kind of plaster is that?
A gypsum plaster, as far as I know. No idea exactly which type. I sent the company a defect notice today and hope it doesn’t all have to be removed...
