Does anyone here have dark gray windows on the interior, as mentioned above – a photo would be great.
I want basalt gray (RAL 7012) windows and am unsure which color to choose for the window handles, roller shutter winder, and roller shutter strap.
Can someone help me decide?
Thank you
Thank you
Ramona13 schrieb:
We have planned DB703 both inside and outside but it hasn’t been delivered yet. Our window installer recommended the stainless steel color, which basically matches everything (even white).
Think carefully about whether you really want strap winder mechanisms; simple tubular motors aren’t very expensive and significantly improve comfort 😉 You can also start with just push buttons/switches and upgrade to smart controls later if needed 🙂 Yes, motors would be great, but I don’t have any power outlet near the windows.
viper599 schrieb:
Yes, having motors would be great, but I don’t have any outlets near the windows. How far away is the nearest power outlet? Since work around the windows is going to get messy anyway, it might be possible to run a cable into the wall. I installed a flexible cable behind the baseboard and a small cable duct behind the radiator, then routed it under the windowsill to the switch. This way, nothing is visible.
In der Ruine schrieb:
How far is the nearest power outlet? When work is done on windows, it’s dirty anyway. Maybe you could run a cable inside the wall. I placed a flexible cable behind the baseboard and a small cable channel behind the radiator, then ran it under the windowsill to the switch. That way, nothing is visible. That’s kind of you to think ahead like that. But I’m getting 9 windows installed with a “no mess” guarantee, and the walls are made of stone (the house is over 100 years old). They would have to chase channels throughout the apartment since each window needs wiring. Still, thanks anyway.
There are already roof windows with solar panels. Isn’t there something like that for regular windows with roller shutter boxes?
