ᐅ Facade paint color for a house with windows in RAL 7016 (Anthracite Gray)?
Created on: 4 May 2023 08:32
BauherrFranken
The contractor gave us a color chart from Maxit. Unfortunately, based on these small color samples, we cannot really imagine what would suit our house with RAL 7016 windows. We quite like Cappuccino. Does anyone have any advice?
Schorsch_baut schrieb:
You can change the facade color every few years on a plastered or wooden house.Not necessarily. Usually, the development plans dictate which colors you are allowed to use. Either everything is permitted, including roof shape and color, or it must be a specific white shade or a particular brick color. The goal is to achieve a consistent appearance across the area. And yes, I also believe in choosing a base color first, which covers about 50-60% of the design of the building. Window frames then become accessories, and benches are cosmetic details. This applies to facades, interiors, clothing, and so on.
If you want to defend your unconventional choice, you can do so, but not like this:
BauherrFranken schrieb:
Now you got what you asked for, huh?I personally find the cappuccino color somewhat dated. It resembles plaster that has weathered over many years. It is often nicely brightened up with white window frames as accents. By the way, RAL 7016 tends to have a bluish tint… there are more attractive contrasts and colors that fit better.
BauherrFranken6 May 2023 14:04ypg schrieb:
There are more attractive contrasts or colors that would be more suitable.Do you have a suggestion which shade you think would be more appropriate?
Do you have a tip on which clay, from your point of view, would be more suitable?Did you not understand my explanations regarding RAL not being like Pantone? How is anyone supposed to give you such a tip without knowing the material, texture, and grain of your plaster?https://www.instagram.com/11antgmxde/
BauherrFranken6 May 2023 20:4811ant schrieb:
Did you not understand my explanation about RAL not being like Pantone? How could anyone give you such advice without knowing the material, texture, and grain of your plaster? By the way: Did I ask you?
By the way: Did I ask you?Funny spell check. Facts don’t matter at all, no matter who reports them. Still, you’re welcome.https://www.instagram.com/11antgmxde/
Keep in mind that the new development area color standard 7016 often appears slightly bluish in sunlight. As mentioned before, RAL colors are not the same as Pantone, and especially 7016 can clash quite noticeably with other colors. Just take a walk through the nearest new development area on a sunny day and see for yourself.
