ᐅ Offer for Double Garage 6x9 m / Foundation and Ground Slab
Created on: 12 Mar 2023 05:19
Peppoderwilde
We requested two quotes from our construction company:
1st Quote
Masonry garage 6.00 x 9.00 m (6.00 x 9.00 meters), including a storage room as part of the residential building work, founded on strip foundations (without gravel filling work, assuming a gravel base provided by the client), the concrete slab will be finished with a rough trowel surface, masonry made of hollow bricks, thickness 17.5 cm (7 inches), exterior facade finished with white plaster, visible wooden beam ceiling, flat roof waterproofing, one sectional door, insulated, size 5.00 m x 2.135 m (5.00 x 2.135 meters), surface woodgrain, M-rib design, color RAL 7016 anthracite gray, with electric drive (electrical connection provided by client) and two remote controls, one side entrance door valued at €2,000.00 gross including 19% VAT, including structural engineering and execution drawings
Additional cost: €47,000.00 gross including 19% VAT
Alternative: Additional cost for interior plaster: €2,900.00 gross including 19% VAT
Alternative: Additional cost for cement screed: €2,510.00 gross including 19% VAT
Alternative: Additional cost for ceiling cladding made of gypsum fibreboards: €2,780.00 gross including 19% VAT
2nd Quote
Reinforced concrete garage slab thickness 20 cm (8 inches) for garage dimensions 6.00 x 9.00 m (6.00 x 9.00 meters) as part of the shell construction of the residential building, founded on strip foundations (without gravel filling work, assuming a gravel base provided by the client), concrete slab finished with a rough trowel surface, including structural engineering and execution drawings
Additional cost: €12,860.00 gross including 19% VAT
I am a layperson and naturally find it difficult to assess the offers. There are surely experts here who can provide an evaluation. 🙂
- Construction of a solid masonry double garage 6x9 m (6x9 meters) as part of building our single-family house
- Construction of a reinforced concrete garage slab 6x9 m (6x9 meters) (preparation for double garage) as part of building our single-family house
1st Quote
2nd Quote
Kati2022 schrieb:
Hmm, I’d like to know how much I would have to pay for our garage (6 by 8.5 meters (20 by 28 feet)) if contracted separately...
[...] Seeing the prices here, that would mean the garage makes up about one-fifth of the house price. Incredible... Why not – if it really amounts to a fifth of the house?
“Incredible” would be if the garage came “instead of flowers” when moving in,
like the grappa Luigi brings when the bill arrives *LOL* *SCNR*
Why not – if it actually accounts for one-fifth of the house?I don’t think so. Maybe if we only consider the floor area, that might be true. The house has extensively insulated foundations and floor slab, higher-quality bricks, complex formwork, and so on...
You’re not going to tell me that I would only order the shell without the double garage if I had to pay 155,000 instead of 195,000. I don’t believe that...
Kati2022 schrieb:
You don’t mean to tell me that I would only order the shell excluding the double garage if I had to pay 155k instead of 195k. I don’t believe that...That’s 40k for a double garage. Crazy prices, yes; those Romans are nuts. But that’s the reality.https://www.instagram.com/11antgmxde/
Peppoderwilde14 May 2023 06:23I need to return to this topic. Is offer No. 2 for planning / structural engineering / foundation slab acceptable or too expensive?
Peppoderwilde schrieb:
I need to return to this topic. Is offer No. 2 for planning / structural engineering / concrete slab? Peppoderwilde schrieb:
Reinforced concrete garage slab, thickness 20cm (8 inches), for a garage measuring 6.00 x 9.00m (20 x 30 feet) as part of the shell construction work for the house, founded on strip foundations (without any gravel placement work, assuming a contractor-provided gravel fill), the concrete slab will have a rough finish, including structural engineering and construction drawings.
Additional cost: €12,860.00 gross including 19% VAT. Peppoderwilde schrieb:
Is this reasonable or too expensive? Thirteen thousand euros (starting from the gravel fill!) just for the slab of a garage supplied by the client, basically just a few wheelbarrows of concrete added on top as part of the house construction, even “including structural engineering,” is not a bargain — not even if the structural engineering were for a garage built by the client themselves. I would almost call that a hostile price ;-)
Peppoderwilde9 Jun 2023 09:14dimba234 schrieb:
No... builds in the Dortmund area and the districts of Paderborn / Soest. We are from the Soest district. We will probably choose a company from Bad Wünnenberg-Leiberg. However, we plan to build a house with a garage. I don’t know if they offer garages separately. Their focus is on single-family homes. Good morning,
which construction company exactly in Bad Wünnenberg-Leiberg is it?
I was able to find several there.
1. Rust...
2. Unserh...
3. Schmi...
4. Dons...
There’s quite a lot going on in Bad Wünnenberg.
