ᐅ Floor plan of a single-family detached house, urban villa style, approximately 2,600 sq ft, without a basement
Created on: 23 Apr 2022 11:06
dkw8074
we now have a plan that is already quite advanced for us. We have been considering for a long time whether to include a basement or not, as well as whether to use the attic space (see also https://www.hausbau-forum.de/threads/ausbau-dachgeschoss-bei-walmdach-als-kellerersatz.43148/).
Building Plan / Restrictions
Plot size: 1170 m² (0.29 acres)
Slope: no
Floor area ratio: 0.4
Floor space index: 2
Number of parking spaces: 2 garage + 1 outdoor
Number of floors: 2
Roof type: hipped roof
Style: urban villa
Orientation: southwest
Owner Requirements
Style, roof type, building type: hipped roof urban villa
Basement, floors: trying to do without a basement
Number of occupants, age: 2 adults, 1 child currently
Space needs on ground floor and upper floor: rooms should be a comfortable size without being excessive
Office: family use or home office? both
Guest stays per year: 10-15 times for 2-3 days
Open or closed architecture: open towards the garden
Conservative or modern design: I would say a mix; in any case, the staircase should not be in the living room
Open kitchen, kitchen island: kitchen with pantry, a fully freestanding island is not necessary
Number of dining seats: 6
Fireplace: yes
Balcony, roof terrace: no balcony, terrace with roof cover
Garage, carport: yes, 2 parking spaces plus motorcycle; 1 additional outdoor parking
Other wishes/special features/daily routine, including reasons why something should or should not be included
Who created the plan: a planner from a construction company
What do you particularly like? Why? We generally like the ground and upper floor because everything we wished for has been implemented
What do you dislike? Why? Placement of building services - perhaps try placing them under the stairs?
Price estimate according to architect/planner: 700k
Personal price limit for the house, including equipment: 800k
Preferred heating system: geothermal
-can you do without: possibly a few square meters; a big question is whether the office/fitness room above the garage makes sense or if a basement would be better
-can’t give up: own master bathroom, laundry room upstairs
We had quite clear ideas based on reviewing standard floor plans. There were some changes and tests (basement yes/no, attic use yes/no).
What makes it, in your opinion, particularly good or bad? Very good implementation of our ideas and budget
The approx. 30 m² (320 sq ft) room on the upper floor (office/fitness) and the larger storage room behind the garage are intended as a basement substitute. How do you like this solution with the partial overbuilding of the garage on the upper floor?
Thank you very much for your feedback!
Slope: no
Number of floors: 2
Style: urban villa
Owner Requirements
Fireplace: yes
Looking at the floor plans without flipping back: is there a reason for the base dimensions? I would make the house about 50cm (20 inches) wider and shorten it by around 100cm (40 inches) in length; that would relieve a lot of pressure, for example cramped hallway situations (including doors) on the upper floor or the master bedroom. Otherwise, and I’m probably repeating myself from before, the main room is simply too dark.
SoL schrieb:
I find the door arrangement in the bedroom wing with the master bathroom impractical. You could end up walking into the bathroom door when trying to get into bed...
I haven’t found a solution yet, though... Thank you very much for the feedback, yes, we have also considered that. Possibly having the bathroom door open inward could work, if it still fits with the toilet layout.
I may have already marked the castle walls with a question mark, and I believe my views on the "master bedroom for elderly" topic are well known. The pantry, fitness room, and utility room strike me as "leftover spaces on the floor plan that have been assigned room names," and overall, I see more of a patchwork than a full redesign here—more or less a forced revisiting of the original draft :-(Thank you very much for your feedback. By "castle walls," do you mean the 50cm (20 inches) bricks?
Regarding the master bedroom for elderly: we are planning the house for ourselves now and for the next 20 to 30 years, so we don’t have to "die" in this house, to put it bluntly.
Yes, we only wanted to optimize and not do a complete redesign because we like a lot of things. Both the pantry and utility room are absolutely fine in terms of size. The office/fitness room will be used more as an office, with an exercise bike as well...
Looking at the floor plans without flipping back: is there a reason for the current dimensions? I would make the house about 50cm (20 inches) wider and shorten it by around 100cm (40 inches) in length. That would ease a lot of things, for example cramped hallway situations (including doors) on the upper floor or the master bedroom. Otherwise, and I might be repeating myself from before, the main room is simply too dark.The plot is a rectangle about 29m by 40.5m (95 feet by 133 feet); making it wider is definitely possible and something we are considering.
Regarding the main room: OK, thanks for your assessment. The sliding patio door will probably be extended to about 400cm (13 feet), but that’s likely it. We are optimistic that, also due to the ceiling height, it won’t be dark.
Yes, by the castle walls I mean the half-brick walls.
I did not criticize the size. What the client and the draftsman come up with is often no less chaotic than the pranks of Max and Moritz. Leaving the "what we like" untouched during revisions is at the core of many so-called underutilized potentials. Even with four decades of experience in home planning, I can’t guarantee that you won’t be happy with your own planning—but I can assure you that a fresh architect’s plan, with a high success rate, is definitely the better way 🙂
dkw8074 schrieb:
yes, we also only wanted to optimize and not do a complete redesign because we like a lot of it. Both the pantry and the utility room we find absolutely fine in terms of size,
dkw8074 schrieb:
Thank you for the feedback, yes, we have considered that as well. Possibly having the bathroom door open inward, which might still work with the toilet layout. …this could be easily resolved by eliminating the angled wall and starting the bedroom a bit earlier near the staircase.
dkw8074 schrieb:
The plot is a rectangle about 29 x 40.5 meters (95 x 133 feet), making it possible to have a wider layout, which is certainly worth considering. Well… as an architect, if I realize I have to resort to angled walls, like in tight townhouses where no more space can be created, I would rather optimize the dimensions from the start and not present something like that to the client at all.
dkw8074 schrieb:
The lift-and-slide door will probably grow to about 400 cm (13 feet). It could also grow to 6 meters (20 feet); the overhang reduces more than 50% of the light gain, which I don’t consider sufficient at all.
