ᐅ Plan the layout of the living area
Created on: 29 Nov 2022 12:12
dertill
We are currently in the process of buying a former farmstead in Schleswig-Holstein (the notary is preparing the purchase contract) to combine living and working (self-employed with animals) under one roof. We, a family of four, will move in together with my mother-in-law on the property. The main residential part is basically ready to move in and is not a topic for discussion here. The part of the building previously used as a barn will be partially converted for my mother-in-law.
About 80m² (860 sq ft) will be used for the apartment, the section facing the courtyard is intended for my wife’s business use or as a guest WC for visitors to the farm. In the middle of the building, between the old residential unit and the barn, there is an unheated, continuous threshing floor. Access to the apartment can be via this area, which can also serve as a corridor for coats and shoes.
I sketched a draft for a possible layout, but somehow it doesn’t feel quite right. I have prepared a questionnaire, shortened for practical purposes:
Zoning Plan / Restrictions
Plot size: Building structure is fixed, listed building, the facade must not be significantly altered
Slope: no
Building envelope, building line and boundary: see above
Number of storeys: Conversion on the ground floor, upper floor is only a hayloft
Roof type: Gable roof
Architectural style: Desired – farmhouse / country house / built around 1880
Orientation: West and North
Other requirements: Facade is protected by historic preservation. Window and door openings are predetermined. In the center, there is a beam with two supporting pillars (circled in red on the floor plan). These cannot be moved. At the lower right is the old milk room. The walls between the milk room and the rest of the barn could be removed. The door shown at the lower left on the plan can be bricked up or equipped with a window / terrace door.
Number of people, age: 1, newly retired, dog
Space needs on ground and upper floors: open-plan kitchen and living room, bedroom, utility room corner, bathroom
Office: family use
Guests per year: almost none, as there is an additional holiday apartment available
Open or closed layout: open plan
Traditional or modern construction style: traditional (not fully clear what is meant)
Open kitchen, kitchen island: yes, island optional
Number of dining seats: 5
Fireplace: no
Music/media wall: small media corner
Balcony, roof terrace: terrace and garden facing north and west, as shown in the pictures, 3D view shows 4 pm in summer
Garage, carport: separate, no need to consider
Vegetable garden, greenhouse: only terrace and secure dog run
Additional wishes / special features / daily routine, including reasons for preferences or rejections
The outdoor area faces north and west, and towards the west there is the road as well as two large (listed) chestnut trees in the garden. My biggest concerns are 1. enough natural light entering the house and 2. some sunlight in the garden as well. For the latter, there is a shared backyard with a southern exposure.
Behind the western wall is the road, outside the built-up area but with little traffic. The wall has not yet been built, but according to the new state building code in Schleswig-Holstein, a height of 2m (6.5 ft) is allowed.
Who designed the plans:
- Do-it-Yourself
What do you like most? Why?
Low finishing effort, walls use existing posts.
What do you not like? Why?
I would like to keep the door at the lower left on the plan as a second exit open, but I haven’t found a space for a media / sofa area.
Price estimate by architect/planner: N/A
Personal price limit for the house including equipment:
Much will be done by ourselves: drywall, floor construction and insulation, electrical work up to the connection box.
Preferred heating system:
Most likely a multi-split air conditioning system (4 indoor units, 1 outdoor unit in the hayloft) and wall-mounted air-to-water heat pump, not connected to the existing central heating system of the house.
If you had to give up, which details/finishes could you skip:
- could skip: everything else is negotiable
- can’t skip: daylight bathroom, open kitchen and dining area
Why is the design as it is now? e.g.:
Requirements of the building structure, historic preservation, and client needs.
How can the living area be planned and divided efficiently without ending up with one big hall and inefficient space use?
Thanks in advance 🙂
dertill
12 Dec 2022 15:59
Once you have set it up, I see a small issue. It’s definitely workable, but with a disability, accessing the window side would be difficult.
The support posts can be shifted from right to left in the plan. In both cases, there are beams running that need to be supported, and at the marked points there are currently posts or, in the case of the milk room, a wall. You can’t just move them “up/down.”
Edit: I only found out over the weekend that they can, of course, be repositioned.
12 Dec 2022 16:09
dertill schrieb:
Simply moving it "up / down" is not possible.
What about the third support at the bottom of the chamber plan?
dertill
12 Dec 2022 16:11
That is the corner of the milk room. From the corner to the left side of the plan towards the exterior wall runs a beam. This beam must be supported at least in one place that is not closer to the exterior wall than the corner currently is – so moving it one meter (3 feet) to the left is no problem, moving it to the right might be. The structural engineer will need to calculate that.
hanghaus2023
12 Dec 2022 16:37
Here is a floor plan including a bathroom. The bathroom has a washing machine and a dryer.
Floor plan of an apartment: living room with dining table on the left, bathroom and bedroom on the right.
It’s a bit easier if the support columns can be moved.
12 Dec 2022 16:52
hanghaus2023 schrieb:
If you can move the supports, it’s a bit easier.
Definitely! However, please take a look at the windows on the lower side of the plan. They are different in your layout. So, if you move the support further to get more than 2.80 meters (9 feet 3 inches) in the bedroom, you will enter the area of the middle window, which is drawn differently in your plan.
hanghaus2023
12 Dec 2022 17:14
Definitely! However, please take a look at the windows on the lower side of the plan. They are different in your version. So, if you move the support further to get more than 2.80 m (9 ft 3 in) in the bedroom, you will reach the area of the middle window, which is drawn differently in your plan.
I used the original poster’s plan. I drew the wall at 2.90 m (9 ft 6 in). The original poster should measure exactly where the windows are located again.
