ᐅ Plan the layout of the living area
Created on: 29 Nov 2022 12:12
dertill
We are currently in the process of buying a former farmstead in Schleswig-Holstein (the notary is preparing the purchase contract) to combine living and working (self-employed with animals) under one roof. We, a family of four, will move in together with my mother-in-law on the property. The main residential part is basically ready to move in and is not a topic for discussion here. The part of the building previously used as a barn will be partially converted for my mother-in-law.
About 80m² (860 sq ft) will be used for the apartment, the section facing the courtyard is intended for my wife’s business use or as a guest WC for visitors to the farm. In the middle of the building, between the old residential unit and the barn, there is an unheated, continuous threshing floor. Access to the apartment can be via this area, which can also serve as a corridor for coats and shoes.
I sketched a draft for a possible layout, but somehow it doesn’t feel quite right. I have prepared a questionnaire, shortened for practical purposes:
Zoning Plan / Restrictions
Plot size: Building structure is fixed, listed building, the facade must not be significantly altered
Slope: no
Building envelope, building line and boundary: see above
Number of storeys: Conversion on the ground floor, upper floor is only a hayloft
Roof type: Gable roof
Architectural style: Desired – farmhouse / country house / built around 1880
Orientation: West and North
Other requirements: Facade is protected by historic preservation. Window and door openings are predetermined. In the center, there is a beam with two supporting pillars (circled in red on the floor plan). These cannot be moved. At the lower right is the old milk room. The walls between the milk room and the rest of the barn could be removed. The door shown at the lower left on the plan can be bricked up or equipped with a window / terrace door.
Number of people, age: 1, newly retired, dog
Space needs on ground and upper floors: open-plan kitchen and living room, bedroom, utility room corner, bathroom
Office: family use
Guests per year: almost none, as there is an additional holiday apartment available
Open or closed layout: open plan
Traditional or modern construction style: traditional (not fully clear what is meant)
Open kitchen, kitchen island: yes, island optional
Number of dining seats: 5
Fireplace: no
Music/media wall: small media corner
Balcony, roof terrace: terrace and garden facing north and west, as shown in the pictures, 3D view shows 4 pm in summer
Garage, carport: separate, no need to consider
Vegetable garden, greenhouse: only terrace and secure dog run
Additional wishes / special features / daily routine, including reasons for preferences or rejections
The outdoor area faces north and west, and towards the west there is the road as well as two large (listed) chestnut trees in the garden. My biggest concerns are 1. enough natural light entering the house and 2. some sunlight in the garden as well. For the latter, there is a shared backyard with a southern exposure.
Behind the western wall is the road, outside the built-up area but with little traffic. The wall has not yet been built, but according to the new state building code in Schleswig-Holstein, a height of 2m (6.5 ft) is allowed.
Who designed the plans:
- Do-it-Yourself
What do you like most? Why?
Low finishing effort, walls use existing posts.
What do you not like? Why?
I would like to keep the door at the lower left on the plan as a second exit open, but I haven’t found a space for a media / sofa area.
Price estimate by architect/planner: N/A
Personal price limit for the house including equipment:
Much will be done by ourselves: drywall, floor construction and insulation, electrical work up to the connection box.
Preferred heating system:
Most likely a multi-split air conditioning system (4 indoor units, 1 outdoor unit in the hayloft) and wall-mounted air-to-water heat pump, not connected to the existing central heating system of the house.
If you had to give up, which details/finishes could you skip:
- could skip: everything else is negotiable
- can’t skip: daylight bathroom, open kitchen and dining area
Why is the design as it is now? e.g.:
Requirements of the building structure, historic preservation, and client needs.
How can the living area be planned and divided efficiently without ending up with one big hall and inefficient space use?
Thanks in advance 🙂
K a t j a3 Dec 2022 12:19
dertill schrieb:
The in-house water plant is shown on the plan in the top right, on the other side of the threshing floor in the basement. Since only cold water and heating will be installed in the new living area, you can plan freely there.
For the existing building, I would first clarify all the connections precisely before designing any further. Where and how are the wastewater disposal, potable water connection, and possibly gas supply arranged?
3 Dec 2022 12:28
K a t j a schrieb:
For the existing building, I would first clarify the connections in detail before starting to design randomly. How and where are the wastewater disposal, drinking water connection, possibly gas?
This is not an existing building; the mother's project involves an unfinished barn.
Myrna_Loy
3 Dec 2022 13:06
Um, before focusing on the floor plan, I would first clarify which fundamental renovation works are necessary to convert the barn into a residential unit. I have never encountered a "low renovation effort" when converting a barn for living purposes. It starts with excavation of the ground, which often extends below the foundation level and requires safety measures, and can include desalination of the walls. Depending on the ceiling structure, it may also be necessary for the building permit / planning permission to reinforce the ceilings structurally. Converting barns for residential use is one of the most expensive remodeling projects I know.
K a t j a3 Dec 2022 14:40
It is not an existing building; the mother’s project involves an unfinished barn.
For me, that still counts as existing structure—one with some of the most expensive and challenging conditions imaginable, especially since it is also under heritage protection. I hope the budget is well prepared. 🙂
Myrna_Loy
3 Dec 2022 16:46
I’m not sure how undemanding your mother-in-law is or what size of living space she’s coming from, but I would avoid the kitchen/guest bathroom combo in that location and instead plan a properly laid-out apartment for your mother-in-law and her dog. The bathroom is by no means suitable for elderly use in terms of dimensions, and I find the access through the kitchen somewhat unpleasant. The bedroom is also quite small if you want to fit a proper wardrobe in there and if she might need to move around with a walking aid at some point. It would be better to have a proper bathroom, a well-sized bedroom, and a small room for an ironing board or eventually for 24-hour care.
hanghaus2023
3 Dec 2022 19:46
I have also given it some thought.
Top-down floor plan of a house with furnished rooms, terrace on the left, and large outdoor area on the right.
