ᐅ Are additional work items during house construction reasonable and fairly priced?
Created on: 3 Nov 2022 22:00
DominicHannove
Good evening,
We have received an offer from a general contractor and are wondering whether the following additional items are reasonably priced and make sense:
1. Compensation for fittings and sanitary fixtures when purchased by the homeowner (warranty only covers up to the rough installation stage; concealed installations remain our responsibility):
Compensation for ground floor WC: Hand basin including faucet, WC including flush control (flush tank remains our responsibility)
Compensation for attic bathroom: 1 washbasin including faucet, WC including flush control (flush tank remains the responsibility of Bösteinhaus), shower faucet and shower set including rail (connections remain our responsibility)
Compensation: €2,420.00
The sanitary fixtures included would be: Brand Vigour series “Derby” or “Derby Style”, alternatively brand Geberit series “Renova Plan” or brand Villeroy & Boch series “O.Novo”; faucets: brand Vigour series “Derby”, alternatively brand Hansgrohe “Talis S” or brand Hansa series “Hansapinto”
2. Removal of the fixed central mullions on double casement windows, replaced by installation of special flush profiles
Additional cost: 3 windows x €160.00 = €480.00
3. Installation of a secondary entrance door as a wooden door to the utility room, offset against the omitted window, including security fittings and insulation matching the front door, solid door leaf, including locking system matching the front door
Additional cost: €2,020.00
4. Installation of a skylight in the attic hallway, approx. 78 x 118 cm (31 x 46 inches), compliant with the energy saving regulations, brand Velux type GGU MK 06 Thermo (pivot window)
Additional cost: €1,360.00
5. Supply and installation of rough tongue-and-groove boarding, 24 mm (1 inch) thick, made of Nordic spruce or fir, dried, staggered installation with screws onto ceiling joists or collar beams
Additional cost: €1,840.00
6. Concrete staircase, white plastered, with beech steps and risers made of washable white Forex panels, with railing according to building specifications and steel handrail or alternatively masonry railing with internal handrail, with storage room and door under the stairs including light outlet and socket
Additional cost compared to standard staircase: €4,800.00
This “standard” staircase would be: A nicely shaped open staircase with solid wood steps in laminated beech, with continuous railing made of modern round tubing
7. Installation of an additional shower in the guest WC as a flush-floor, tiled design approx. 90 x 150 cm (35 x 59 inches) with installation of one floor drain and required large-area sealing, wall enclosure up to 2.10 m (6 ft 11 in) height according to drawing, shower area tiled to 2.10 m (6 ft 11 in) height; shower faucet and shower set including rail to be provided by homeowner
Note: a shower partition must be installed by the builder on-site
Additional cost: €1,990.00
8. Creation of a tiled niche in the shower in the ground floor WC, approx. 30 x 60 cm (12 x 24 inches)
Additional cost: €340.00
9. Creation of a masonry and tiled shelf behind the washbasin in the ground floor WC, height 1.20 m (4 ft), approx. 0.8 linear meters
Additional cost: €200.00
10. Installation of an additional cold water connection in the ground floor WC next to the toilet (for future installation of a bidet spray by the builder)
Additional cost: €290.00
11. Creation of a tiled shelf next to the bathtub according to drawing, height approx. 50–60 cm (20–24 inches)
Additional cost: €190.00
12. Installation of a laundry chute from the upper bathroom to the utility room (ground floor), 300 mm (12 inches) spiral seam pipe with laundry bag and secured flap for inserting laundry
Additional cost: €1,160.00 (alternative: laundry chute as homeowner’s own work, we provide only ceiling opening 350 x 350 mm (14 x 14 inches), additional cost: €180.00)
13. Installation of all switch boxes in deep form for retrofitting wireless smart home systems by own work
Additional cost: €560.00
14. Installation of AEROPAC SN (Siegenia AUBI) demand-controlled ventilators. Draft-free and whisper-quiet operation, individual air regulation, dust filter function, including core drilling and socket
Additional cost: number of bedrooms 4 x €1,100.00 each = €4,400.00
What do you think?
Are there items that are overpriced?
What would you include and what not? (I know some are very individual. For these, I’m more interested if the additional cost is reasonable.)
Are there individual items I should better leave out initially and commission later with the respective specialist?
We would appreciate any advice.
DominicHannove
6 Nov 2022 18:28
kbt09 schrieb:
Recessed spotlights in the ceiling? Then the electrician appointment is actually too late.
We are building with solid construction, and the start of construction is planned for March.
WilderSueden
6 Nov 2022 20:13
For recessed lights, there needs to be an opening in the ceiling. Nowadays, this is usually done as a semi-prefabricated component with a topping layer. The location of the recessed light must already be specified in the plans when ordering at the concrete plant.
Normally, several empty conduits for the electrician also run inside the ceiling. These must be sufficient in number and positioned correctly. So, if you want to add 10 more outlets for your multimedia room, it will be too late once the electrician arrives.
kbt09
6 Nov 2022 20:20
Thanks @WilderSueden for the additional clarification. @DominicHannove, what should be clear is that it’s not enough to simply feel something is too expensive or to receive tips like “you can just arrange it with the contractor on site.” You should understand or inform yourself enough about the specific issues to know when to initiate what, because there won’t be anyone coordinating that for you. I already referred to this in post 17 on https://www.hausbau-forum.de/threads/nachtraegliche-balkon-befestigungs-vorrichtung.44428/, simply to give a sense of such matters.
Pacmansh
6 Nov 2022 20:23
WilderSueden schrieb:
So if you want to add 10 more outlets for your media room, it will be too late once the electrician arrives.
It was different for us. There was a meeting with the electrician during the shell construction phase, and the locations for outlets and switches were discussed then. However, for anything that needed to be done in the ceiling, it was already far too late at that point; that would have had to happen much earlier.
DominicHannove
6 Nov 2022 20:25
kbt09 schrieb:
Thanks @WilderSueden for the additional explanation. @DominicHannove, what should be clear is that it’s not enough to just feel something is too expensive or to get advice like “you can just arrange it with the contractor on site.” You need to understand or educate yourself enough about the different aspects to know when to initiate what, because no one will coordinate it for you. I already referred to that in post 17 in https://www.hausbau-forum.de/threads/nachtraegliche-balkon-befestigungs-vorrichtung.44428/, simply to give an idea of something like this.
You are reading into this something I never said...
There has been no tender from the general contractor to the trades yet! I can still finalize everything, make changes, and so on..
WilderSueden
6 Nov 2022 20:33
Pacmansh schrieb:
It’s different for us. There was a meeting with the electrician during the shell construction phase, where the locations for sockets and switches were discussed. But anything that needed to be done in the ceiling was already far too late by then; that should have been planned much earlier.
We had that meeting too. Inside the rooms, it’s relatively straightforward—the individual cables run under the screed in the floor and then go up through chases. But empty conduits were cast into the ceiling so the electrician wouldn’t have to drill through it. An empty conduit was also laid for the terrace connection, but in the meantime, we redesigned the terrace from south to west. It wasn’t a disaster; the electrician just drilled through. Still, it would have been smarter to have it in the right place from the start.
DominicHannove schrieb:
You’re reading into this something I never said...
There hasn’t been a tender from the general contractor to the trades yet! I can still finalize all the samples, make changes, and so on...
You can still do that, but not everything without involving the general contractor. You have to know which details need to be finalized when, and as a layperson, that’s really hard to judge.
