ᐅ Is it possible to have a connection box for TV (satellite) and LAN?
Created on: 11 Oct 2022 00:45
netzplanhanse987 schrieb:
Why do you want a combination socket? One network outlet on the TV is often not enough to avoid needing an additional switch. Depending on the devices connected to the TV, it can even make sense to install two double network outlets.What hanse987 says.
I even have double satellite sockets everywhere instead of single ones. These are installed in real empty conduit to allow replacing the coaxial wiring with CAT cables if needed.
If I were to build today, I would probably build without satellite. If satellite is essential, then it’s worth looking into Sat over IP and planning the corresponding network cabling.
hanse987 schrieb:
Why do you want a combo socket? I have a power outlet, LAN, and TV socket on two different walls. The second wall is more of a "backup" in case the occupant wants to rearrange the living room differently. So I thought it would be better to keep the sockets compact.
Most of my friends and acquaintances use Wi-Fi. But yes, a double network socket wouldn't be a bad idea either.
Michilo schrieb:
Search for "gira rj45 f socket" Cool, great. Exactly that.
RFR schrieb:
If satellite TV is essential, then look into SAT over IP and plan the appropriate network cabling. Great advice. I’m hearing about this for the first time and will check it out right away. Then having two network cables especially makes sense.
