I have a well-insulated KFW40 house from 2014 with underfloor heating and 170m² (1830 ft²) using a Weishaupt gas boiler WTC 15 (heating + hot water).
The gas boiler has two heating circuits. One for the house and the other for the garage. The garage is connected via a district heating pipeline (about 8m (26 ft) from the house). The garage should only be kept frost-free.
My annual gas consumption (heating + hot water) was about 9700 kWh.
I believe my house is well suited for a heat pump. Unfortunately, I wasn’t that knowledgeable back then.
Now my questions.
1. Which type of heat pump would you recommend (ground source or air source)?
2. Where can I install the heat pump? A) Inside the house, where the gas boiler is now, or B) in the garage? Unfortunately, the heat pump could not produce hot water in the garage because there is only a cold water line to the garage. Or are there any solutions? I would prefer the garage otherwise.
I hope you can help.
Thank you.
Now my questions.
Thank you.
Vwgolfcabrio schrieb:
Does anyone have experience with the Panasonic Geisha air-to-water heat pump? It is relatively affordable. How is the domestic hot water production implemented? Are there square hot water tanks? The round ones don’t look very elegant. Our plumber from the well-known area is enthusiastic about them, saying they are top-quality units at a good price. Unfortunately, the conditions for dealers are apparently not great, which is why he mostly installs Wolff equipment (simply a better margin). I’ll quote his statement.
V
Vwgolfcabrio8 Aug 2022 09:41Alessandro schrieb:
What a tip 🙄
As an amateur, you don’t mess around with water or electricity in the house! The advice is to order the appliances from abroad. The conditions there are somewhat better. But everyone has to decide for themselves.
In the future, we will have to do much more ourselves. At least then I know exactly what I have done.
Alessandro8 Aug 2022 09:47And who will install it and provide a warranty? You won’t find a (reliable) craftsman for that...
V
Vwgolfcabrio8 Aug 2022 10:45Alessandro schrieb:
And who will install them and provide a warranty?
You won't find a (reliable) tradesperson... You have to bite the bullet. I will assemble them entirely myself, of course with the help of a system installer.
You have to bite the bullet. I will assemble it entirely myself, of course with the help of a system installer. Then, in the worst case, if it is installed incorrectly or breaks after a year, you save a lot but have no warranties.
V
Vwgolfcabrio8 Aug 2022 11:11Roookie schrieb:
Then, in the worst case, it’s installed incorrectly or breaks after a year, so you save a lot without any guarantees. But that’s not the point of this article at all. Everyone can decide for themselves here. Over the past years/decades, I’ve always had good results with this. You don’t get any less knowledgeable from such a project, either. At the very least, you realize how many so-called experts and specialist companies are out there in the market.
