ᐅ New Single-Family Home Construction – Join Us on Our Journey!
Created on: 4 Aug 2022 16:13
gregman22
Dear community,
We are finally getting a step closer to realizing our dream of building a single-family home.
The plot has been purchased, building plans have been reviewed, construction method decided, and so on. We have now commissioned the architect of the general contractor (GC) of our choice with the planning task and are currently fine-tuning the house design. I would love to take you along on this journey and incorporate your valuable feedback.
At this stage, the focus is on the house design.
Basic data:
Plot: 1062m2 (11,433 sq ft); approx. 25.5m x 41.64m (84 ft x 137 ft)
Orientation: Northwest -> The arrow in the screenshot of the 3D view points south
Desired room layout:
Ground floor:
First floor:
Attic:
Note: I am still discussing this with the architect. Due to the hipped roof shape, the actual living area has shrunk too much. Therefore, further discussion is needed to accommodate the other rooms. I had underestimated the ratio of gross floor area to usable living space.
Basement:
Additional plans:
Now to my first questions for you:
My biggest construction challenge at the moment is the layout of the attic. There are two alternatives:
- Change the roof type, which would increase costs but provide more usable living space in the attic
- Give up the playroom on the first floor, convert it into a guest room, and build only the two offices in the attic (no guest room or bathroom)
Thank you in advance for your comments.
Basic data:
Ground floor:
- Large living/dining area with adjacent (but separable) kitchen at the bottom left, plus a gallery overlooking the first floor
- Utility room
- Guest toilet
- Garage
- Separate apartment at the top right with its own entrance for parents-in-law
First floor:
- Gallery overlooking the ground floor
- 2 children’s bedrooms with a shared bathroom
- 1 playroom (initially a home cinema room, later to be repurposed) above the garage
- Master wing with main bedroom, dressing room, and bathroom
Attic:
- 2 separate offices
- 1 guest bedroom
- 1 small guest bathroom
Basement:
- 1 technical room
- 1 laundry room
- 1 storage room
- Large fitness room
- Wellness room with sauna
Additional plans:
- Air-to-air heat pump or air-to-water heat pump
- Photovoltaic system with/without battery storage
- Possible pool (3.5/4m x 8m or 3.5/4m x 12m) with heat pump (and countercurrent system)
- Sauna in the basement room
- Air conditioning for various rooms
- Smart home system – most likely via KNX
- Garden: Currently planning 2 terraces – one to the left, slightly more to the south, and one facing the main part of the plot further north
- How do the floor plans strike you? Do they make sense in terms of the dynamics of family life?
- The location of the separate apartment was chosen based on our wish. We wanted a strict, clearly defined spatial separation with a separate entrance. Do you have any comments on this?
- Do you consider the utility rooms in the basement to be adequately sized (considering KNX, heat pump, etc.)?
gregman22 schrieb:
The layout of the granny flat was designed according to our wishes. We wanted a clear, strict spatial separation with a separate entrance. Do you have any comments on that?Yes, I have one comment. Is it intentional that the terrace is shared and that you can see into each other's living rooms? Maybe consider what will happen if, instead of your parents-in-law, some unrelated tenants move in.
Knautnaundorf4 Aug 2022 20:04I think the garage is way too small. 34 sqm (approximately 366 sq ft)? What is supposed to fit in there?
I would leave out the open space above, as it seems pointless.
Where is the chimney for the fireplace?
Where is the Bavarian style? Shutters, roof overhangs, some wooden accents without all this uniform gray?
The room layout is completely inefficient. The bedroom is larger than the garage. Bathrooms should always be planned stacked on top of each other. This makes many things easier. You can place all the utilities in a single service shaft and retrofit a lot later on.
Two cars in the garage are already very tight, and with a bicycle, you can no longer get through between them.
How many parking spaces do you actually need? Usually, 1.5 to 2 parking spaces per housing unit are required. The area in front of the garage is not always recognized as a separate parking space, as otherwise unusable parking spots could result.
gregman224 Aug 2022 21:27I find the points of criticism absolutely valuable – keep them coming!
Regarding the garage: we have two cars, one of them an SUV. Unfortunately, the garage cannot be widened due to setback requirements. To do that, I would have to modify the entire house.
About the open space: that is our personal preference. We want to extend this sense of space from the ground floor upward. We currently live in a maisonette apartment with a gallery – and we really like it.
Fireplace: good point. It’s indeed not included yet.
Regarding the exterior design: you are right. In the fine-tuning phase, I definitely want to work out some small but significant enhancements with the architect. It’s great to already have some ideas ready.
