ᐅ Skim Coating to Level 2 / Two Coats of Paint – Is That Sufficient?
Created on: 10 Apr 2022 09:19
E
Elias_dee
We received the following offer for our single-family home – is this quality sufficient, or should we pay extra for Q3? Or is it acceptable if Q2 is painted twice?
"All interior wall surfaces of the brick masonry will receive a skim coat of lime gypsum plaster. The walls in wet rooms will be finished with a lime-cement plaster. Corner protection strips will be installed on external edges and reveals. Movement joints will have movement profiles. Interior plaster surface quality Q2. The ceilings in the living areas will be fully and securely filled. Wall and ceiling surfaces will receive a two-coat opaque dispersion paint finish in white."
Crixton
11 Apr 2022 18:50
Prager91 schrieb:
We wanted the ceiling to be completely smooth and the walls to have a fine texture.
We had everything finished to Level 2 drywall standard and then decided to have the entire ceiling skim coated twice and then spray painted. It looks absolutely awesome, and I would definitely recommend it every time.
For the walls, I also recommend applying a primer coat (quartz primer) and then a second layer of textured plaster (decorative quartz). Our plasterer suggested painting another coat, but we decided not to. It already looks amazing to us.
Are you talking about a drywall partition?
A plastered wall already has the texture of the plaster itself.
Prager91
12 Apr 2022 07:18
Crixton schrieb:
Are you talking about a drywall?
A plastered wall already has the texture of plaster.
No, a plastered wall. If you simply paint a plastered wall with emulsion paint, the texture remains quite rough and "bumpy" – I don’t really like that, especially not for living areas. That’s exactly what I did in the basement – and it was fine there.
Using textured plaster creates a completely different effect.
Neubau2022
29 Apr 2022 14:41
We also have Q2. After seeing it, I would actually describe it more as Q3. We want walls as smooth as a baby’s bottom. Therefore, the painter will fill, sand, apply painter’s fleece, and paint twice again. The cost for the entire bungalow, 141 sqm (including ceilings), is approximately €9,000 gross.
Tolentino29 Apr 2022 14:53
Neubau2022 schrieb:
Costs for the entire bungalow, 141 m² (including ceilings), approximately €9,000 gross.
That is very inexpensive. Locally or also from Poland?
Neubau2022
29 Apr 2022 15:00
Tolentino schrieb:
That is very inexpensive. Local or also from Poland?
Local. Even one who collaborates with the general contractor. But I contacted him through a recommendation from an acquaintance :-)
Here is the quote:
Cost estimate interior finishing: wall and ceiling work, plastering and painting
Tolentino29 Apr 2022 15:06
Hmm, strange. I didn’t have much more living space (164m² (1765 sq ft)), but a lot more surface area to paint (600m² (6458 sq ft)). Did you leave out a lot? Especially the painter’s fleece partial service is incredibly cheap. What weight do you use?
