I am considering whether to install a downdraft extractor integrated into the cooktop or a ceiling-mounted extractor hood.
The situation is as follows:
The cooktop is on an island.
The room height is approximately 2.75m (9 feet).
What would be the best solution in this case?
Regards
Regards
XXXRXXX schrieb:
The kitchen is open.
No fireplace.
The island is about 370cm x 120cm (145 inches x 47 inches) in size.
I have no preferences.Then at least a modern unit like that fits underneath, since the thing takes up cabinet space.ypg schrieb:
At least a modern unit like that fits from below, since it takes up cabinet space. It should be affordable.
Paying 3000€ for one is too expensive for me.
Ideally, I would like a 90 cm (35 inch) cooktop from Neff with a ceiling-mounted hood above it.
However, I can't find anything affordable with a width of 120 cm (47 inches), and my high ceiling makes me a bit concerned about whether the hood can be installed low enough.
XXXRXXX schrieb:
It should simply be affordable.
Paying 3000€ is too expensive for me. For a SIEMENS model, you pay about half that. And our cooktop with extractor – in use now for 3 1/2 years – is doing a good job.
We have something like that from Franke... and for higher ceilings, there are “adapters,” also available in stainless steel. Back then, it was 400€ (we were careful with money too 😉 )
Benutzer20027 Apr 2022 18:46XXXRXXX schrieb:
The island is approximately 370 x 120 cm (12 ft 2 in x 3 ft 11 in) in size.I think a Berbel Skyline Frame would be great for that – you can also put small items on it, and it has good extraction power.Oops – I just saw your budget...
