ᐅ What degree of deviation is acceptable when laying masonry?
Created on: 8 Apr 2022 19:46
WilderSuedenW
WilderSueden8 Apr 2022 19:46We visited the kitchen installer today and then went to the construction site where the ground floor was completed this week. We noticed that the kitchen measurements differ slightly from the original plan. According to the plan, the kitchen should be 2.995 meters wide, but I measured 2.909 meters along the wall and about one centimeter more at the transition to the dining area.
I understand that masonry work isn’t exact to the millimeter ("the bricklayer is happy as long as he stays on the property..."), but around 8 centimeters seems a bit much to me. Is this still acceptable, and what would be the best way to handle this? Should I ask the general contractor to have the bricklayers on the upper floor re-measure more carefully? In principle, I could live with a kitchen width that’s about one handbreadth smaller.
gutentag schrieb:
Does that make the entire room smaller? That seems likely, unless the opposite wall has also been moved accordingly.
Is the wall thicker, or crooked, or is the room behind actually larger? 🙄
9 cm (3.5 inches) off target is unacceptable.
Is there no site manager?
WilderSueden8 Apr 2022 20:32I don’t know if the room behind is larger. Unfortunately, I didn’t think to measure everything thoroughly. In general, I would assume that some parts are missing; the plans are full of 40cm (16 inches) walls, but the bricks are 42.5cm (17 inches) long (question: would this still be considered a minor change?). However, this alone doesn’t explain the deviation.
I never questioned the irregular measurements. They were already included in the initial draft, are part of the building permit / planning permission application, and were incorporated into the construction plan as well.
WilderSueden8 Apr 2022 20:43Similar topics
