who has installed a tablet wall mount?
If yes, which bracket was used and what type of power supply was chosen?
Regards
Symbols Symbols Symbols Symbols Symbols SymbolsSymbols Symbols SymbolsSymbols Symbols Symbols
Regards
BW MR BW MR23 Feb 2022 16:22face26 schrieb:
Somewhere for sure... I'll check... but probably later this evening. Alright, sounds good.
Maybe also the bracket.
Thanks
Quite clever to save all your emails for the entire construction project in a separate folder.
The power supply was called 2usb chargeUP 12W, ordered from a shop that doesn’t scam but rather the opposite 😀
The wall mount is the Displine Companion Wall, which I believe I ordered directly from the manufacturer.
BW MR BW MR23 Feb 2022 16:44face26 schrieb:
Very practical to save all your emails for the entire construction project in a separate folder.
The power supply was called 2usb chargeUP 12W, ordered from a shop that doesn’t cut corners but rather the opposite 😀
The wall mount is the Displine Companion Wall, which I believe I ordered directly from the manufacturer.Thanks.Did the mount cost you €150 (about $160)?
BW MR BW MR schrieb:
Thanks.
Did the bracket cost you 150€ as well?Not quite, I think it was around 130 or 140 back then. But among the simple, flat designs, that’s already on the cheaper side. It can get much more expensive.
I also think the price depended on the size.
Grolsch3024 Feb 2022 07:35We have a Biffar front door with an integrated iPad mini, but we are waiting for the electrician to connect it along with the digital peephole and ekey fingerprint system.
Rorit202024 Feb 2022 09:16Hello...
... I have installed a Lenovo Yoga Smart TAB (Android 10) at my place. It has a fold-out aluminum stand on the back, into which I simply drilled two holes. There are two threaded inserts in the plate, and I attached the tablet with two knurled screws. This way, it can be easily removed if needed. The Lenovo Smart Tab also has a desktop mode, where the tablet does not charge if the battery is still above 60%. The speakers are really good, so notifications sound quite “professional.” I also bought a charging cable with a right-angled flat plug. It’s actually a simple solution (tablet price about 180 euros) that works pretty well for me...
