BW MR BW MR10 Feb 2022 09:12Hello,
is there anyone here who is quite familiar with calculating a strip foundation?
The foundation is for a bungalow.
Regards
Regards
O
Osnabruecker10 Feb 2022 09:30No.
With thousands of readers following this, there is no one here who can help you with your precise question.
(By that I mean: you need to provide a bit more information… do you actually mean cost estimation (= €) or structural design?)
BW MR BW MR10 Feb 2022 09:35Osnabruecker schrieb:
No.
Out of thousands of readers here, there is no one who can help you with your precise question.
(Meaning: you will need to provide a bit more information... do you actually mean cost estimation (= €) or structural calculation?)I just wanted to know if there is anyone here who can assess this before I provide more information.
BW MR BW MR10 Feb 2022 09:38O
Osnabruecker10 Feb 2022 10:03Not a good setup.
Too little square meters of topsoil (scaffolding, workspace?).
How thick is the topsoil?
Where will the topsoil be stored?
For the excavation work, the existing heights and the geotechnical report must be known.
For the foundations in the PDF, I’m missing a magnifying glass, but you should be able to calculate that yourself using length × width × depth.
The structural analysis specifies the quantities of steel.
BW MR BW MR10 Feb 2022 10:14Osnabruecker schrieb:
The setup is not good.
Too little square meters of topsoil (scaffolding, working space?)
Where will the topsoil be placed?
For the excavation work, you need to know the existing ground levels and soil report.
For the foundations in the PDF, I’m missing a magnifying glass, but you should be able to calculate length × width × depth yourself.
The structural engineering specifies the amount of steel required. Topsoil and excavation material from the foundations will be placed on the side.
The foundations are about 70m³ (92yd³).
