ᐅ Is it worth preparing for air conditioning installation?
Created on: 2 Feb 2022 16:36
Pwnage619
We are considering planning for air conditioning preparation in our new build.
In which rooms does it make sense to install air conditioning?
We have a KfW 55 semi-detached house.
What needs to be done for air conditioning preparation?
pagoni2020
2 Feb 2022 18:59
Pitigliano schrieb:
So I’m wondering to what extent you are even allowed to install an air conditioning system here without jeopardizing your KfW 55 subsidy?!
Exactly, that is what needs to be taken into account. It might be possible, but only the wind knows the answer... um, I mean the energy consultant.......
Pitigliano
2 Feb 2022 19:12
pagoni2020 schrieb:
Exactly, that is what needs to be taken into account. It is possible, but only the wind… erm, the energy consultant… knows the answer.......
Does anyone know how long the KfW is allowed to check/sanction the subsidized energy certificate?
matte
2 Feb 2022 19:13
If I were to build again, I would install the necessary connections (don’t forget condensate drainage!) in every room that is used regularly and for longer periods. Children’s rooms could possibly be excluded.
We have air conditioning installed in the bedroom and my office. By now, I regret not having one in the living area as well.
Thanks to the photovoltaic system, operating costs are kept very low.
Considering that heatwaves are becoming hotter and lasting longer, I wouldn’t base it too much on the orientation of the building. If you have Mediterranean-like temperatures every day, even the north-facing rooms will eventually get warm.
It’s simply a matter of comfort.
pagoni2020
2 Feb 2022 19:23
Pitigliano schrieb:
Does anyone know how long the KfW can monitor or impose sanctions related to the subsidized energy performance certificate?
I don’t know for sure, but I’m confident the period is long enough that such concerns should quickly fade if you want to sleep peacefully.
Mycraft2 Feb 2022 20:25
@matte1987
easy to retrofit in the open space, there’s always a way 😉
matte
2 Feb 2022 20:47
Yes, sure. There would even be a drain pipe in the wall behind it where I could access the condensate. The outdoor unit would be right next to the exterior wall on the carport roof, also very close by.
I've already thought it through; it's not like that! 😉
But it would only be possible with bigger and, above all, messy work.
My wife would probably think I'm crazy at first, and I’m not feeling the pressure to deal with it just yet... 🙂
