ᐅ Solid wood parquet on underfloor heating
Created on: 12 Feb 2021 10:38
Absinthe
Yesterday, we had an appointment at our hardwood flooring studio. We were recommended a solid hardwood floor from the company ALI Parquets. It is supposed to be fully glued down.
Another supplier recommended a two-layer engineered wood floor from Bauwerk.
Online, you often read that solid hardwood flooring is generally not suitable for underfloor heating. Is that true?
Unfortunately, I can’t find many reliable reviews about either manufacturer. Does anyone happen to have one of these installed in their home?
DaSch1718 Jan 2022 09:40
I just spoke with Meister’s technical support. Regarding the functionality of underfloor heating, it does not matter whether it is installed as a floating floor or glued down. When installed as a floating floor, the underfloor heating system is only slightly slower to respond.
A bigger issue, according to Meister, is the size of the open space. The parquet should not be installed continuously over more than 10m (33 feet). This means that expansion joints in the form of small aluminum strips or cork strips must be placed in the middle of the room if you want to install the floor as a floating floor. If the parquet is glued down, this is not necessary.
Tolentino18 Jan 2022 09:49
Oh yes, that's right, for some it is even only 8 m (26 feet).
ateliersiegel18 Jan 2022 11:40
DaSch17 schrieb:
It doesn’t matter whether you install it as a floating floor or glue it down.
There are different opinions on this.
In our case, gluing is planned because it is said that heat transfer between the screed and wood parquet is significantly "worse" when not glued.
My common (healthy?;)) sense, combined with what I learned in school—that energy cannot just "disappear"—tells me that a floating installation behaves as mentioned above (less effective than glued), because: where should the heat go? It stays in the room. 😎
DaSch1718 Jan 2022 11:47
It’s great how thoroughly and quickly we have worked through this topic. I’m impressed! Thanks to everyone!
RotorMotor
18 Jan 2022 11:49
ateliersiegel schrieb:
My common sense(?;)) combined with my school knowledge tells me that energy cannot "disappear" and that with floating installation it is, as mentioned above, slower than glued down, because: where should the heat go? It stays in the room. 😎
Since this statement has been repeated, I would like to add that this is not entirely correct.
Ultimately, it’s all about heat transfer, simplified.
First, between the inside and outside through walls, windows, etc.
And second, between the heating system and the interior space.
To compensate for heat loss to the outside, heat must be supplied by the heating system.
If insulation such as impact sound insulation, air layers, (and the parquet floor itself, which has high insulation) slow down or reduce the heat transfer from the heating system into the room, the supply temperature must be higher.
As a result, the system is not only slower but also consumes more energy!
Additionally, this can lead to increased losses, for example through the ground floor slab or basement.
In der Ruine18 Jan 2022 11:56
My common (?;)) sense tells me—combined with what I learned in school—that energy can’t just “disappear” and that, when installed as a floating floor, it behaves as mentioned above (more flexible than glued), because: where else would the heat go? It stays in the room. 😎
For me, it’s a different matter. It’s not just about the floor being warm. The room needs a certain amount of energy to compensate for losses through walls, windows, and doors. But if the floor cannot transfer this energy quickly enough from the heating pipes to the air, the heating system might not be sufficient. This could mean a higher supply temperature is necessary. How else would insulation in a jacket, a wall, or something similar work?
