ᐅ Light Wells – Are They Worthwhile? Options, Costs, Examples, Spacing...
Created on: 16 Jan 2022 22:22
HoisleBauer22H
HoisleBauer2216 Jan 2022 22:22So far, I have not found a general discussion thread about light wells. Here are some questions I have:
1. How much light does a light well actually provide? For example, can it be replaced by two or three light shafts if that is cheaper?
2. What costs should be expected in southern Germany for a simple light well with gravel and basic concrete or natural stones for securing it?
3. How should a light well be protected against heavy rainfall or flooding? Water drainage (cleaning issues if leaves, etc. get inside), backflow preventer, and similar measures.
4. What would be a suitable size (width, height) for a basement window for a light well? What are the costs?
WilderSueden16 Jan 2022 22:50What do you have in the room? The more time you spend in it, the more light you will need.
HoisleBauer2216 Jan 2022 23:02Ah, I forgot to mention: it’s about using the space as an office where people stay at different times throughout the entire weekend, and sometimes work from home on weekdays (sometimes in the morning, sometimes in the afternoon).
Alternatively: use as a bedroom.
For a storage room or workshop, natural light wouldn’t necessarily be required 🙂
For an official living space, about 1/10 of the floor area should be glazed with windows. More is preferable. This determines the size of the light well or light shaft.
Light shafts are usually prefabricated and mostly vertical. Light wells are typically built on-site, often deeper and larger with a sloping design to allow more light to enter. They can be finished with stones or plants. Cleaning involves going down, collecting leaves, and removing them. A good drainage system with gravel, similar to a house perimeter drainage, prevents water accumulation.
Costruttrice16 Jan 2022 23:36For a bedroom or a regularly used office, I would choose a light well. Otherwise, I personally would feel somewhat confined, but that is purely a subjective feeling.
Knecht offers nice solutions for basements, such as light strips and light floods, which I find attractive and which do not take up as much space as a light well.
In any case, remember to include an emergency exit in the basement.
HoisleBauer2217 Jan 2022 23:49Costruttrice schrieb:
Knecht offers attractive solutions for basements, light strips, and light wells; I find them visually appealing, and they take up less space than a light court. I looked at the catalog, very appealing solutions. How much does a light strip cost? Or a light well? Do you have any ideas or experience?
Definitely remember the emergency exit in the basement. That must be a window you can climb out of (with a ladder?), right?
For an official habitable room, about 1/10 of the floor area as window area. Floor area = room size or wall surface where a window can be installed? If room size: for a 14m² (150ft²) room, that would only allow a window of 1m x 1.40m (3ft 3in x 4ft 7in)...
And finally: how much space does a light court require? For example, is 4m (13ft) to the neighbor enough if the basement is fully underground, meaning not raised at all?
