ᐅ Reducing Air-to-Water Heat Pump Vibrations on the Exterior Wall
Created on: 12 Dec 2021 10:27
bauherr201615
bauherr201615
12 Dec 2021 10:27
Hello, we have an air-to-water heat pump mounted on the exterior wall of our house.
After about 5 years, I have the impression that the pump is starting to vibrate more and more, and these vibrations naturally transfer into the house, causing disturbance. When the pump is running, if you touch the window from inside, you can clearly feel the glass vibrating.
My question is: How can I, as a layperson, reduce these vibrations? Would it help to realign the heating system?
Mycraft12 Dec 2021 10:30
The device must be positioned as horizontally as possible, preferably on machine feet, meaning rubber-mounted.
It is completely normal for it to become louder and for vibrations to increase over time, as bearings and other components wear out.
Tolentino12 Dec 2021 10:35
Place them on the floor? A foundation with thick rubber feet on top, which are actually offered by almost every heat pump manufacturer. They look like parking stops...
tomtom7912 Dec 2021 10:36
I wouldn’t hesitate for 5 seconds and would place the unit directly on the ground.
bauherr201615
12 Dec 2021 10:51
tomtom79 schrieb:
I wouldn’t hesitate for five seconds and would just place the unit directly on the ground.
Can I manage this without a certified refrigerant technician? Because I can’t commission the system since the refrigerant line is already connected.
Mycraft12 Dec 2021 10:56
It depends on whether you still have enough refrigerant line to relocate the unit. Alternatively, you can build the foundation base exactly to fit the current installation position.
