ᐅ Window sill height 130 cm in the bedroom / home office?
Created on: 23 Nov 2021 17:37
audiophilone
Hello... we have the following issue. Since we don’t want too many different window heights in the house and also don’t find the transition from a 130cm (51 inches) sill height to a low window in the same room or at the junctions particularly attractive, we are facing the above-mentioned problem. Actually, I’m not even sure if it’s really a problem.
West elevation of a two-story house as an architect’s design drawing with windows and entrance door.
South elevation of a modern building with garage on the left, multiple windows and flat roofs.
North elevation of a modern building, two levels, rows of windows and dimension lines.
East elevation of a modern house with flat roof, large window front and doors.
Smialbuddler
23 Nov 2021 18:02
Do you have small children? They won’t be able to see outside at all with a height of 130cm (51 inches). And you will have much less view, none at all when sitting.
Regarding brightness: The higher the window sill, the farther away from the window even direct sunlight will reach when the sun is high. Think about the angles.
hampshire
23 Nov 2021 18:09
The bedroom will have a large skylight above the bed that opens up like a convertible roof – sleeping outdoors in comfortable temperatures is a great feature!
The study will have a strip of windows from above, for example, above the desk area – this provides very pleasant natural lighting as long as it’s bright outside.
Due to the parapet of the flat roof, the roof surfaces are not visible from the outside as a design feature.
A nice but somewhat energy-consuming option is an access to the roof, for example from the hallway, so that the skylight can be cleaned from time to time.
Of course, the window area then reduces the available space for rooftop photovoltaic panels.
23 Nov 2021 18:11
audiophilone schrieb:
Meeting all aspects is not easy, and that’s exactly our problem. @ypg But don’t you think a 265cm (105 inches) and a 201cm (79 inches) window won’t let in enough light?
A narrow slit never lets in as much light as a surface opening or “hole.”
audiophilone
23 Nov 2021 18:12
No, we don’t have children, but if we do in the future, the children’s room has a window with a 90cm (35 inch) sill height. The view doesn’t bother us because we have large windows on the ground floor for that. Well, I think with a sill height of 130cm (51 inch) and a window height of 90cm (35 inch), there is still plenty of indirect light coming in.
audiophilone
23 Nov 2021 18:15
I think installing windows in the roof will probably be significantly more expensive, and the project is already with the structural engineer who is just waiting to do the calculations... meaning we don’t have much time left to make changes.
audiophilone
23 Nov 2021 18:18
But maybe someone has an idea on how to make the exterior and interior more balanced?
