ᐅ Floor Plan for a 150 sqm Bungalow with Garage
Created on: 30 Oct 2021 21:56
E
Eckert93
Plot size: 870 m² (9,375 sq ft)
Slope: 3% over 22.9 m (75 ft)
Number of parking spaces: minimum 4 + garage
Number of floors: 1
Roof style: hipped roof, 28 degrees
Design style: undecided
Orientation: terrace facing south/west
Homeowner Requirements
Number of residents, ages: 2 persons, children planned, 28 and 29 years old
Guests per year:
Number of dining seats: 2, with a small breakfast nook planned in the kitchen
Fireplace: yes, with external air supply (drain pipe under the floor slab)
Garage, carport: Garage with utility room approx. 37 m² (400 sq ft), carport 36 m² (387 sq ft)
Planner: DIY with implementation by architect
What do you like most? Why?: The long sight lines filled with natural light.
What do you dislike? Why?: Folding stairs in the children's room, but it has to be somewhere. In the hallway it would be too prominent.
Price estimate from architect/planner: 330,000 € without kitchen, fireplace, carport, and landscaping
If you have to give up anything, which details/extensions
-can you do without: carport
-can’t do without: garage
Are there any experiences with the Vaillant flexotherm exclusive with uniSTOR 300 l (79 gal)?
Vinyl flooring or parquet?
Ceiling spotlights in the hallway loft from Werkaus, or better to install yourself?
I would really appreciate tips and your opinions about the floor plan!
Best regards, Eckert
E
Eckert93
31 Oct 2021 08:58
driver55 schrieb:
You’ll need to explain that in more detail. 🙄
If everything is already finalized, you’re bringing the plans too late to the table.
There’s no collective pat on the back for this floor plan, as you’ve noticed.
I also find the living/dining/kitchen layout kind of “strange.” Basically, these are three separate rooms without doors.
We wanted to keep the option open in case we eventually get tired of the open entrance area.
And basically, we do like the floor plan. Switching the bedrooms, etc., I still need to discuss with my wife—that’s definitely something to consider.
31 Oct 2021 09:18
driver55 schrieb:
I also find living/dining/kitchen somewhat “unusual.” Basically, they are three separate rooms without doors.
It’s just not standard… but that doesn’t say anything about whether it’s good or bad. Something isn’t strange just because it’s not standard 😉
hanghaus2000
31 Oct 2021 09:49
Is this an architect from the home builder?
Are only bungalows built in the surrounding area?
E
Eckert93
31 Oct 2021 09:53
hanghaus2000 schrieb:
Is that an architect from the home builder?
Are only bungalows built in the area?
An independent architect who often collaborates with the construction company.
There are several bungalows around, but also regular two-story houses... However, the immediate neighbors are bungalows as well.
31 Oct 2021 09:54
The roof is higher than the exterior wall… it looks like a hat set too low… I think the proportions are a bit off. The roof should have a steeper pitch.
driver55
31 Oct 2021 09:55
It’s definitely not run-of-the-mill… but that doesn’t say anything about whether it’s good or not. Although it is a bit unusual if it’s not standard 😉
I didn’t say, “it is strange,” but rather, “I find it strange.”
To me, 60 sqm (645 sq ft) of living/dining/kitchen space is hardly functional if, when dining (a bit exaggerated here), I’m half sitting in the kitchen/hallway/vestibule. That area feels like a thoroughfare.
Bright, light-filled rooms are great, but not like that.
