ᐅ Bungalow Floor Plan for 3 People, 130 sqm – Looking for Opinions...
Created on: 14 Jul 2021 13:22
Z
Zweithaus
Hello, I would like to hear your opinions. What do you think? Are there any suggestions for improvement? The west side faces open fields, so we wanted the living room to be oriented that way.
Plot size: 900 sqm (9,688 sq ft)
Flat land
Floor area ratio 0.4
Building line and boundary: 3 meters (10 feet)
Number of floors: 1
Roof style: gable roof and flat roof
Architectural style: modern
Orientation: west
Small office, only for emergencies
3 people aged 38, 38, and 2
No overnight guests
Large kitchen with dining area, separate living room, covered terrace
- Do-it-yourself
We considered all the desired rooms.
Access from terrace directly to kitchen and bathroom.
The main house will have a gable roof to allow attic space for storing boxes. The pull-down staircase can be installed in the long hallway. The part with the covered terrace will have a flat roof. However, we are not sure if having two types of roof will be expensive.
We also like a modern gable roof with trapezoidal metal roofing. This should be quite affordable… does anyone have experience with that?
I attached a picture of various houses that inspired us.
Does anyone have a rough idea of the cost? We are still very early in the process and many builders are reluctant to provide quotes due to uncertain material prices.
Construction is planned for 2023.
Flat land
Number of floors: 1
Orientation: west
No overnight guests
- Do-it-yourself
Large, dark, unwelcoming entrance area / hallway.
22% of the living space.
The darkness could be improved by adding a window near the stairs, but the entrance area would not really become better, just slightly brighter.
The kitchen/dining area and the “living square” are basically fixed, and the rest is an attempt to create a good floor plan by shifting walls. This doesn’t work because you always end up in the same dead end.
The access to the terrace behind the stove is inconvenient (it has always been this way, but I only just noticed it).
The guest toilet has been “squeezed out”? 🙄
Z
Zweithaus23 Oct 2021 09:02evelinoz schrieb:
Endless space
[ATTACH alt="bungalow-grundriss-3-personen-130qm-bitte-meinungen-535187-1.PNG"]66342[/ATTACH]
Main entrance opposite the kitchen door, toilet according to the plan to the right next to the utility roomThanks, I’ll try to implement that right away! ☺️Similar topics
