ᐅ Design of a Single-Family House Floor Plan (Convertible to a Two-Family Home for Later Use) on a Sloped Site
Created on: 1 Apr 2021 21:58
Seppl's Häusle
Plot size: 440 m² (4,736 ft²)
Slope: steep slope of 30° - 40° in the rear area, 7-10 m (23-33 ft) towel-shaped plateau along the street
Floor area ratio: not applicable, suitable
Gross floor area ratio: not applicable, suitable
Building envelope, building line, and boundary: no zoning plan, building permit for another project already approved
Edge development: single-family house, 2 full stories, mostly gable roof, but also flat and hipped roofs
Number of parking spaces: 2 required (no trapped parking space)
Number of stories: 2 full stories plus partial basement on the south-facing slope
Roof type: gable roof
Design style: open to planning
Orientation: hillside facing southwest
Maximum heights / limits: unknown
Other requirements: no zoning plan
Owners’ Requirements
Style, roof type, building type: gable roof, timeless both inside and out
Basement, stories: partial basement (on the slope) + 2 full stories (see cross-section)
Number of people, ages: 2 adults + 2 children
Space needed on ground and upper floor: approx. 85 m² (915 ft²) per floor
Office: initially none, if needed in guest room or basement
Overnight guests per year: hopefully many 🙂
Open or closed architecture: compromise, as the two apartments should remain separable in old age on ground and upper floor
Conservative or modern construction: as above
Number of dining seats: minimum 4
Fireplace: yes, in the conservatory
Balcony, roof terrace: yes, on the basement level, 2.5 m (8 ft) facing south
Garage, carport: yes, on the east side by the main entrance
Utility garden, greenhouse: terraced garden planned with usable areas
Other wishes / special features: no water connection in the basement to avoid a lifting system. Therefore, laundry room in the upper floor instead of basement. It is located by the stairwell so it can still be used in old age when the upper-floor apartment is separated by a door.
Who designed it:
Planner from a construction company together with us
What is especially liked? Why?
Open floor plan on the ground floor combined with private retreat areas on each floor. Bay window facing south (downhill side), conservatory, and terrace there as well
What is disliked? Why?
Basement and shape of the basement are not entirely satisfactory but likely cannot be changed due to staircase position in the stairwell.
WC and room on the ground floor feel cramped; have not found a better solution as access should not be through the main hallway
Cost estimate: none yet
Personal price limit including fittings: as long as we stay under 5 million, everything is fine 😀
Preferred heating system: solar combined with pellet heating
What you could live without
-could live without:
Upper floor bathroom is still very large; could be smaller
-cannot live without:
Ability to separate living units for old age, bay window in the living room
Why is the design like this?
The plot has a towel-shaped plateau measuring 22 m (72 ft) wide and 7-10 m (23-33 ft) long. The house’s mass will be placed there. A seating area/garden is planned to the west with access from the kitchen via a few meters of wooden terrace. The slope on the south side drops steeply. The garage and a parking space at the driveway will be located on the east side.
Windows are positioned symmetrically from the outside perspective, which is why their arrangement on the ground and upper floor appears a little unusual.
We want to use the plot as it is, not fight against it. The unobstructed south view should be emphasized. The sightline from the entrance through the hallway, glass door over the dining table to the garden in the west should make the house feel spacious. Three old trees on the plot will be integrated into the garden. Inside, we aim for minimalism and a timeless living feel.
We welcome all suggestions and ideas but also have clear concepts that can hopefully already be seen in the floor plan.
Is there anything you think we should consider or improve?
Thank you very much for your support 🙂
Who designed it:
hanghaus2000 schrieb:
Spend the money on a lawyer experienced with building on slopes. This won't work otherwise. What does he need a lawyer for? .... 30 characters...
Seppl's Häusle19 Oct 2021 19:36ypg schrieb:
What does he need a lawyer for? .... 30 characters...I wonder that too!? But I can’t reach 30 characters 😀H
hanghaus200021 Oct 2021 09:37Seppl's Häusle schrieb:
I wonder the same!? But I can’t reach 30 characters 😀 Sorry, I obviously meant architect
Seppl's Häusle21 Oct 2021 10:25hanghaus2000 schrieb:
Sorry, I meant architect, of course.I think we can manage that as well... I'm optimistic, and a good planner can be better than a bad architect :p
Have you ever considered providing external access to a second dwelling unit in case of scenario X?
A staircase that ends on a balcony?
The two entrances and the stairwell require a lot of space, which you will miss in the open-plan area. The wardrobe takes up 1.5 m² (16 ft²) of hallway space, even if it is not officially designated as such.
On the ground floor, you have many small, almost too small, living areas that are arranged around the hallway and the unfurnished open space (I somehow like that expression).
Try drawing all the furniture to scale and take into account the necessary circulation space.
