ᐅ Evaluation of floor plan for approximately 145 sqm single-family house with basement, ground floor, and upper floor
Created on: 14 Oct 2021 12:44
Arango18
Zoning plan/restrictions: Zoning plan and restrictions considered by the architect
Plot size: 675m² (7260 sq ft)
Slope: yes, running diagonally across the plot (see elevation plan)
Building window, building line and boundary: 3 m (10 feet) on all sides
Edge development: yes, neighbor to the southeast
Number of parking spaces: 2 in garage and 2 in front of garage
Number of floors: 2.5
Roof type: gable roof, 36 degrees
Architectural style: simple
Orientation: southwest
Maximum heights/limits: same as neighboring buildings, sufficiently high
Other requirements: none
Street: cul-de-sac; our house is at the end, with neighbors on one side and open view of forest, meadow, and valley on the other
Owners’ requirements
Style, roof type, building type: interior as open and straightforward as possible, exterior simple
Basement, floors: basement, ground floor (GF) and upper floor (UF)
Number and age of occupants: currently 2 (both 28 years old), planning 1-2 children
Space requirements for GF, UF: approx. 140 m² (1507 sq ft) of living space
Office: absolutely necessary due to 80% remote work
Guest bedrooms: very rare use
Open or closed layout: open
Conservative or modern construction: conservative (mostly because it’s usually more affordable)
Open kitchen, cooking island: open kitchen with bar or island (due to space and layout, more likely a bar)
Dining seats: 4-6
Fireplace: planned but not mandatory
Music/stereo wall: standard TV wall
Balcony, roof terrace: small terrace on the slightly extended garage towards southwest, terrace towards southeast
Garage, carport: double garage with a single door
Utility garden, greenhouse: standard
Other wishes/notes/daily routine, including reasons why some things are wanted or not: a small shower in the guest WC is very important to us, as well as a small room for the home office. Since I work from home 80% of the time, this is essential. Also, a small storage room for vacuum cleaner etc.
Who designed it: architect
What do you particularly like? The dining and living area looks bright and cozy in our opinion. Not too big and not too small with a great view.
What don’t you like? Why? Bathroom layout feels too tight and awkward, hallway in the upper floor too narrow?
Preferred heating system: air source heat pump
If you had to give up some features, which ones?
Fireplace
Why did the design end up like it is now?
The original design was larger and included more details such as corner and roof windows, but it was optimized for cost.
However, the room layout and overall room concept basically remained unchanged.
I would appreciate further suggestions, especially regarding the aspects we don’t like. Overall, we are quite happy with it. Do you see any major “no-gos”?
If any information is incomplete or unclear, I’m happy to check it again.
Dining seats: 4-6
Fireplace
I think you should exclude the entire basement level from the thermal envelope. That means: a partition wall/door to the stairs in the basement. The office can be heated electrically. Arango18 schrieb:
What exactly are the advantages of excluding the basement from the thermal envelope? Sorry if this sounds like a silly question. Energy cost savings? But it also increases construction costs, right? That’s nonsense. Excluding the basement from the thermal envelope makes no sense if the office remains there. It is a living space and would then need to be individually enclosed within a thermal envelope. I won’t even comment on the electric radiator.
Arango18 schrieb:
What exact advantages does the basement level have by being inside the thermal envelope?It can be built more cost-effectively 🙂Arango18 schrieb:
We already had a recess for a coat rack in the design before, but unfortunately, it didn’t work out and made the living room too cramped :-(And where is it planned now? There isn’t much space in the middle of the hallway… How do you imagine that working with two children? Just removing it won’t help!M
Myrna_Loy14 Oct 2021 19:32The storage room could also be used as a cloakroom. If you have a basement.
Myrna_Loy schrieb:
The storage room could also be used as a wardrobe, if there is a basement.I wrote that. #29. But it would be interesting to know how the original poster envisions it.
Arango18 schrieb:
The terrace next to the house facing southeast towards the neighbor is located on that side because the sun shines there in the morning and around midday. A terrace facing north, on the other side of the house, would be better in terms of view and privacy, but you would never get any sun there.
Attached is also the view from the upper edge of the property (east) towards the west.The view is great, and I would definitely mirror the house! On a north-facing terrace, you do get sunlight—in the morning from the east and in the evening from the west. Only during the midday heat would you need a second terrace to really enjoy the sun. On the southeast terrace, you are not only right next to your only neighbor but also in the shade in the evening.
That it can be built more cheaplyAs a utility basement, yes – but that's not how we have it here.https://www.instagram.com/11antgmxde/
