ᐅ What type of shelf or storage is recommended in a shower for a new build?
Created on: 30 Aug 2021 13:04
Pwnage619
we are considering which shower shelf would be practical for shampoo and similar items in a new build.
A shower niche is not possible (it would reduce the shower floor space and make the shower too small for us).
These shower baskets keep falling off ://
What alternatives are there for new builds that are also durable and visually appealing?
It should definitely be something sturdy and resistant, capable of holding a few kilograms.
Hangman30 Aug 2021 13:56
... our shower stuff has been standing on the floor for decades, but we are rather low-tech anyway. Otherwise, there are also fixtures that can be used as shelves.
Pwnage619
30 Aug 2021 13:57
For the shower niche, the wall needs to be made thicker, which would reduce the shower size to only 75-80 x 90 cm (30-31 x 35 inches) instead of 90 x 90 cm (35 x 35 inches). We don’t want that.
I also don’t think the option with tiles in the corner is bad, but that would have to be installed immediately when the wall tiles are glued, right?
Which high-quality options can you specifically recommend that could possibly be installed by myself? It should be high quality and durable.
30 Aug 2021 14:00
Pwnage619 schrieb:
Which high-quality options can you specifically recommend that I might be able to install myself? It should be durable and long-lasting.
You’ll have to do the product research yourself 😉
Pwnage619
30 Aug 2021 14:14
Unfortunately, I can only find that cheap 0185 junk.
That’s why I would appreciate a tip.
guckuck2
30 Aug 2021 14:31
Just take a look at well-known brands on their websites. Or check major online plumbing supply stores, for example the one starting with R near Mönchengladbach. They also have a category for shower baskets in the bathroom section.
30 Aug 2021 14:55
Pwnage619 schrieb:
Unfortunately, I can only find cheap 0185 junk.
That's why I would appreciate a recommendation.
Amazon is not helpful in this case either. Have a look at Reuter and check the well-known manufacturers there.
