ᐅ Air-to-Water Heat Pump: Current Consumption and Data
Created on: 29 Sep 2020 11:06
Bookstar
Hello!
I'll start.
KfW 55 standard
Electricity consumption 9 kWh
COP 3.88
guckuck2
29 Aug 2021 15:44
Hangman schrieb:
What is this, this "Sun"???
That bright sphere that always provides energy when it’s not dark outside 🙂
O
Oetzberger
29 Aug 2021 15:52
guckuck2 schrieb:
This bright sphere always provides energy when it’s not dark outside 🙂
Are you talking about vanilla ice cream? Sugar helps.
Bookstar
30 Aug 2021 10:51
Every year again 😀 right? Here, it's been around 12°C (54°F) continuously. I'm quite surprised that my heating system is still off and it’s still 21°C (70°F) indoors.
But I think it will turn on soon if it doesn’t get any warmer.
I checked the heating energy consumption during the summer. It uses about 3 kWh daily for standby and hot water. I’m not sure if that’s efficient, but it adds up to around 90 kWh per month, which costs about 25 euros.
nordanney
30 Aug 2021 11:35
Bookstar schrieb:
I checked how much energy the heating system uses during summer. About 3 kWh per day for standby and hot water.
I typically use around 1 to 1.2 kWh per day – usually one shower a day, occasionally more than one. Now I can finally join the conversation after the heat pump has been running for some time.
berny30 Aug 2021 13:02
Bookstar schrieb:
Every year again 😀 right? Here it’s actually been around 12°C (54°F) continuously.
Hi, it seems we’re "fellow sufferers" when it comes to the heat pump. Here, I have already manually run the underfloor heating a few times in May, June! and also now in August during the day, after heating up the hot water and the battery was full. Rather than almost giving the electricity away to the utility company…
seat8830 Aug 2021 17:00
I offer 0.0, gas heating...
(remaining words)
