ᐅ Floor plan of a 1.5-story house with a captain’s gable, covering just under 200 square meters
Created on: 18 Jul 2021 18:13
blubbernase
blubbernase
18 Jul 2021 18:13
hi, we have been going back and forth with the work and wanted to get your opinion
Development Plan/Restrictions
Plot size: 673 m² (7239 ft²)
Slope: 3.5% incline from one side to the other
Floor area ratio: 0.2 (Floor area ratio I: 134.6 m² (1450 ft²), Floor area ratio II: 201.9 m² (2172 ft²))
Building envelope, building line and boundary: see picture (the side lines mark the property borders)
Edge development: new residential area, detached houses
Number of parking spaces: 1
Number of stories: max 1 full story
Roof type: gable roof
Architectural style: captain’s house
Orientation: ridge runs northwest to southeast
Maximum heights/limits: eaves height 4.5 m (15 ft), ridge height 9 m (30 ft), reference point in development plan nearly 1 meter (3 ft) above plot level, brick facing required, dormers allowed on only 50% of the eaves length
Style, roof type, building type: gable roof
Basement, stories: partial unheated basement, ground floor, upper floor
Number of occupants, ages: 34 m, 33 f, 3 m, 4 f + 1 planned
Space needs on the ground floor: 1 office, 1 office/guest room, kitchen with dining area, living room, bathroom with shower, entry hall
Space needs on the upper floor: 1 bedroom, 3 children's rooms, 1 full bathroom, 1 toilet with washer/dryer
Office: 100% home office
Overnight guests per year: 1 per month, mother-in-law
Conservative or modern construction: practical?
Kitchen: kitchen with dining area, table to be inside the kitchen
Number of dining seats: 6
Fireplace: no
Music/sound wall: no
Garage, carport: garage for one car and bicycles
Utility garden, greenhouse: maybe later
Ground floor: floor area 107.5 m² (1156 ft²) (including stairs)
Upper floor: floor area 101.2 m² (1090 ft²) (including stairs)
Basement: approx. 70 m² (753 ft²)
Designer: designed by ourselves using Sweet Home 3D
Basically, we based the exterior dimensions on the Whiteline promotional house "Kiefernallee" from Gussek Haus and extended it about 50 cm (20 inches) longer on the left side of the gable. We have been working with Gussek Haus for a while. Initially, we had a floor plan with 4 gables and a longer house, but we discarded it due to complexity. The upper-floor layout is still based on that promotional house, but the ground floor has changed quite a bit.
What do you particularly like? When entering the house, you’re not immediately in the living room.
Price estimate according to the architect/planner: base house approx. 450,000 € (including move-in ready) + 60,000 €
Personal price limit for the house including basement: 550,000 € + additional costs and fittings
Preferred heating system: air-to-water heat pump with indoor unit
If you had to give up something, which details/extensions?
- You could give up: basically nothing 😀
- You could not give up: a few extra square meters here and there
Why did the design turn out this way?
For example: it fits well on the plot, although the terrace is quite small.
Will the long hallway annoy us despite being reasonably wide?
Brick house with red gable roof, two dormer windows, several windows and garage
Two-story brick house with red gable roof, beige extension on the left, glass windows and terrace on the right
3D model of a red brick house with red roof, side extension and terrace with table.
Large brown brick house with green gable roof, extension and gray outbuilding on snow.
3D model of a red brick house with red roof and attached garage
Orange brick house with yellow gable roof, two stories, multiple windows; picnic table on the left.
Floor plan of one level with several rooms: bedroom, bathroom, hallway, living room, dimensions in m².
Floor plan of a house: living room, kitchen, dining area, bedroom, bathroom, hallway, garage.
Basement floor plan: sports room 16.86 m² (181 ft²), technical room 16.88 m² (182 ft²), storage hallway 20.69 m² (223 ft²), basement/children’s room 13.8 m² (148 ft²).
Floor plan of a residential house with living room, kitchen, bedrooms, bathroom and garage on the right.
hanghaus2000
19 Jul 2021 08:29
The property looks familiar to me. Could you please link your relevant post?
driver55
19 Jul 2021 09:33
Phew,….
46 sqm (500 sq ft) hallway with stairs on the ground floor/first floor + 8 sqm (85 sq ft) entrance area? 😳
(or are the 12 sqm (130 sq ft) stairs included? Then it would be 42 sqm (450 sq ft) including living space) The rest is like in a (poorly laid out) 150 sqm (1,615 sq ft) house.
Apart from being expensive, due to what feels like 48 corners, I don’t see any “highlights.”
(270 sqm (2,900 sq ft) vs. 550k€ max)
First, this needs to be “cleaned up,” or the goal needs to be clearly defined.
19 Jul 2021 10:21
https://www.hausbau-forum.de/threads/feedback-zu-unserer-grundstueckswahl-erwuenscht.37911/page-4
Take a look here. It should be plot 27, where the neighboring driveways are each 2.50 meters (8 feet 2 inches) wide.
Aerial view of a residential area with numbered plots and planning boundaries
19 Jul 2021 10:51
I also find the house a bit too "confusing" with many corners and edges. A similar floor plan has already been discussed here...
Personally, I find it too closed off. The hallway to the living areas is too long.
The pantry, with a depth of just under 60cm (24 inches), is the size of a tall kitchen cabinet – its usability is questionable.
Are the bathrooms on the upper floor disqualified because of the sloping ceiling?
K1300S19 Jul 2021 11:01
What are those colored blocks supposed to be in the entrance area?
I think the upper floor is okay. The ground floor, on the other hand, is way too convoluted for my taste. You should definitely consult an architect, and do so WITHOUT these scribbles.
