ᐅ How to Construct a Covered Entrance for a House
Created on: 1 Jul 2021 14:17
KonstantinW
KonstantinW
1 Jul 2021 14:17
I am looking for some constructive solutions for a canopy at the entrance area.
On the right side, we have a small bay window that projects about 1.20m (4 feet) out, then the entrance area, and then the garage, which is roughly at the same level as the bay window.
The gap between the bay window and the garage (about 6 meters (20 feet)) should be covered, as shown in the example photo.
I am now searching for suggestions on how to construct this canopy between the bay window and the garage.
Thanks in advance for your help.
Modern white house facade with gray garage, entrance door, planter, and garden area.
Example photo. (here, the garage is not at the same level as the bay window as in my case)
Ground floor plan of a single-family house with living/dining area, kitchen, hallway, bathroom, WC, garage; red outline.
Ground floor plan (area marked in red shows where the canopy should be)
East view: two-story house with garage on the left, window front and entrance, pitched roof.
Front view
hanghaus2000
1 Jul 2021 14:31
A roof is not necessary. You will enter the house through the garage 90% of the time.
By the way, what does your planner say about covering the entrance?
KonstantinW
1 Jul 2021 14:37
hanghaus2000 schrieb:
A roof is not necessary here. You will enter the house through the garage 90% of the time.
Otherwise, what does your planner say about covering the entrance?
Well, it’s more for the appearance. It looks better with a continuous roof covering.
I was thinking of using steel profiles or wooden beams from the garage to the bay window, then cladding and plastering them. Of course, there should be a slope for rainwater drainage towards the bay window and the garage.
The planner didn’t say anything about this. He wasn’t constructive in that regard, which is why I wouldn’t recommend him.
hanghaus2000
1 Jul 2021 14:41
How far along is the planning? Implementing your wishes is the planner’s job.
With the garage extending forward and the higher bay window, that will be difficult.
MM1506zzzz
1 Jul 2021 16:43
Is the garage already built, or has the garage’s foundation slab already been poured? If not, then consider moving the garage further back so that it aligns flush with the house, allowing you to create the canopy as shown in the photo.
KonstantinW
1 Jul 2021 17:10
How far along is the planning? It's the planner’s job to implement your wishes.
With the protruding garage and the higher bay window, that will be difficult.
Planning and structural engineering are complete.
The architect is rather negative about the roofing. I think I would discuss this separately with a roofer.
If the garage has a height of 3m (10 feet) and the bay window 3.20m (10.5 feet), and the heights are gradually aligned, wouldn’t that look less appealing from the front view?
