ᐅ Floor Plan for an Urban Villa with a Gable Roof, 140 m²
Created on: 19 Jun 2021 13:24
E
Einfachmachen
I have been a silent reader for some time now, and we are currently planning our floor plan. I would appreciate hearing your opinions on it.
In my view, it is a standard design with a few small special features. We really like it so far and would implement it as it is currently planned.
Maybe you will notice something that is particularly poorly designed.
Thank you very much!!
Plot size: 420 sqm (4520 sq ft)
Slope: Yes
Site coverage ratio: 140 sqm (1507 sq ft)
Floor area ratio: 2 full floors
Number of parking spaces: 2 including garage
Number of floors: 2
Roof type: Gable roof, 25 degrees
Architectural style: Urban villa
Orientation: South/East
Basement: No basement
Number of occupants, ages: 3 x 32/32/4; planning completed
Room needs on ground and upper floors: See floor plan
Office: Family use or home office? Both
Overnight guests per year: None
Open or closed architecture: Open
Conservative or modern style: Modern
Open kitchen with island: Open
Number of dining seats: minimum 6
Fireplace: No
Music/sound system wall: No
Balcony or roof terrace: No
Garage or carport: Yes
Other wishes/special features/daily routine, including reasons for why or why not
Planning by:
- Planner from a construction company: YES
What do you particularly like? Why?: Air space, large and many windows, optimal room requirements
What do you not like? Why?: Nothing so far
Preferred heating system: Air-to-water heat pump
Plot size
Slope
Site coverage ratio
Floor area ratio
Edge development
Number of floors
Roof type
Architectural style
Orientation
Maximum heights / limitations
Other requirements
Basement, number of floors
Fireplace
Balcony, roof terrace
Garage, carport
Utility garden, greenhouse
Other wishes / special features / daily routine, including reasons why or why not
Planning by:
- Architect
- Do-it-yourself
Personal budget limit for the house including fixtures and fittings:
Slope: Yes
Number of floors: 2
Fireplace: No
Planning by:
Plot size
Slope
Site coverage ratio
Floor area ratio
Edge development
Number of floors
Roof type
Architectural style
Orientation
Other requirements
Fireplace
Garage, carport
Planning by:
- Architect
- Do-it-yourself
For example, I built 140 m² (1507 sq ft), including the basement, but the footprint remains the footprint.
At a scale of 1:100, I don’t think you can tell from the shell dimensions whether it’s 1.20 m or 1.40 m (4 ft or 4 ft 7 in).
But don’t worry too much about it; there are many opinions. Take from them what you think has potential for improvement. Check if the floor plan meets your preferences. If you want plenty of light from midday to evening, all living spaces need to face south and west. If you want evening sun in the upper floor, you need window areas facing north.
Our preference, for example, was for the ground floor to be completely open with lots of window space, and all three children’s bedrooms located upstairs while minimizing wasted space as much as possible.
My plan was also discussed. That comes with sharing your floor plan for discussion.
The slope issue hasn’t been talked about yet either. It’s quite possible your floor plan isn’t suitable for a sloped site, so don’t get too attached to it. If you’re planning a central mechanical ventilation system with outlets in the ceiling of the upper floor, then the floor plan might not work, and so on. A floor plan depends on more than just whether you like the layout.
Einfachmachen schrieb:
I feel the same way now. You can't compare a 140 sqm (1507 sq ft) house to one with 160 sqm (1722 sq ft). We understand that some areas might not be ideal (hallway 1.20 m (3 ft 11 in) wide), but there is hardly any way to reduce width anywhere. Exactly. Keep the staircase where you like it.
Change the bedroom, make the kid’s room smaller, enlarge the office. And if, at some point, you realize the living room is too dark, or there’s too much open space between dining area and sofa, and it always feels drafty, then sell and build a new house.
Zaba12 schrieb:
Take from wherever you think there is room for improvement. Exactly.
Zaba12 schrieb:
The slope issue hasn’t been discussed yet either. Exactly… then we start again and ask for the site plan 😉
E
Einfachmachen22 Jun 2021 21:21Yes, I understand it that way now too. The site plan will be ready tomorrow evening!
E
Einfachmachen22 Jun 2021 21:34Zaba12 schrieb:
At a scale of 1:100, I don’t think you can tell from the shell dimensions whether it is 1.20 or 1.40. This has been bothering me anyway 😀
The distance between the two walls of the kitchen and the staircase is exactly 2.51 meters (8 ft 3 in). The clear width of the staircase is 1.00 meter (3 ft 3 in), so there is 1.51 meters (4 ft 11 in) left in the hallway. Of course, the clearance is a bit less directly at the entrance area because of the 90-degree start of the stairs, but only for the first meter (3 ft 3 in) 🙂
The distance between the two walls of the kitchen and the staircase is exactly 2.51m (8.2 ft). Including the wardrobe, which takes up 60cm (24 inches) more? 😉
How do you even come up with the idea to cut the measurements? I thought you were just a silent reader 😀
E
Einfachmachen22 Jun 2021 22:19ypg schrieb:
Including the wardrobe, which takes up 60cm (24 inches), right? 😉
How do you even come up with the idea to cut out the measurements? I thought you were just a silent reader 😀 No no, I used the wall after the wardrobe as the reference 🙂
