ᐅ Chases in Exterior Walls – Should They Be Filled with Mortar?
Created on: 16 Jun 2021 15:40
Appel2000
As part of routing the wiring for the lamps on the exterior facade, we will need to cut a few grooves into the masonry (Poroton).
They won’t be very deep, of course, but with Poroton, larger pieces can sometimes break out unexpectedly.
Question for the group:
What should I use to fill these grooves after the cables are installed? That is, before plastering.
Regular mortar? Or do I need to consider potential thermal bridging? Are there insulating mortars available?
Or is this not really relevant and will be addressed by the exterior plaster?
Thanks and best regards
Appel200016 Jun 2021 16:21danixf schrieb:
Does the protective conduit run from the distribution point all the way to the end?Yes, from the distribution point to the spot where it currently comes out at the exterior wall... with a bit of extra length as usual...
danixf schrieb:
Classic...Tell me about it...
danixf schrieb:
If a large section does get damaged, you can use some mortar. Type MG 2 should be sufficient. But anything smaller than a fist-sized area will be handled by the plasterer.Thanks!
Appel200016 Jun 2021 16:23Tolentino schrieb:
I wouldn’t change anything. Once it’s plastered and soil is filled in around, she won’t even notice...😀 😀 😀
That’s certainly one approach.
But here are a few points to consider:
- She notices almost everything
- and then I’ll have complaints for the rest of my house life
- and usually, I can rely on her opinion regarding appearance and style
hampshire16 Jun 2021 17:00Appel2000 schrieb:
- She notices almost everythingA wonderful talent! Appel2000 schrieb:
- and then I’ve had complaints all my life in the houseA somewhat wonderful way to handle that talent.With flat cable, you should be able to install it flush in the wall without chasing. See if you can find something very slim with the appropriate specifications.
Appel200016 Jun 2021 17:02That is certainly an option as well, using the flat cable.....
hampshire schrieb:
A little wonderful handling of the talent.If you want to turn the charming girl here next to you at the altar into a nagging woman, then answer with "Yes!" ;-)https://www.instagram.com/11antgmxde/
