ᐅ Which wall paint color would you recommend?
Created on: 19 May 2021 17:16
Mathodo
Now that the question of wallpaper or not has been answered, I would like to ask about wall paint recommendations.
At the hardware store, there is a brand called Alpina; it’s called Renovierweiss and costs 25 euros for a 10l (2.6 gallons) bucket.
Is it suitable to buy this, or should something higher quality be used, such as Brillux, for the walls?
Regards, Markus
danixf
19 May 2021 19:19
KingJulien schrieb:
I have never had any issues with Alpina, cheap paint from Obi, or anything in between. They all make the wall white.
I have a self-employed master painter as a good friend, and he quickly moved away from cheap paint. Depending on the wall area, you have to apply 3 to 4 coats. Patchy wall surfaces are also not uncommon. I think in the end, it’s about the volume. If you’re painting a room here and there, then the inexpensive paint from the home improvement store will do the job.
Personally, I don’t like painting at all and want to get it done quickly — which means a maximum of two coats. We painted our entire house with Brillux Superlux 3000 and I have nothing negative to report, except perhaps the price.
Myrna_Loy
19 May 2021 19:34
My favorite for regular walls is Keim Biosil. It is easy to apply, creates attractive surfaces, and is safe for health and environmentally friendly.
KingJulien19 May 2021 19:48
danixf schrieb:
Depending on the wall area, you'll need to paint 3-4 coats.
I once painted a bright orange apartment with paint from a hardware store. What can I say? It covered well with the first coat.
So, I have always been satisfied with hardware store paint. Although, I don’t have to do this every day.
On the other hand, what’s 200 or 300 euros difference for paint when building a house?
So, go ahead and treat yourself.
I also chose the expensive paint (Alpina) for my house. 😉
jcan
19 May 2021 19:48
You should first clarify what is important to you. Personally, I also prefer Keim paints and in my own house I only use Biosil. Innostar is also a good paint, which can sometimes cover in just one coat.
But first, it’s important to consider what properties you need. Should the paint be especially abrasion-resistant, washable, or rather have the characteristics of silicate paints? Take a look at the differences between silicate and dispersion (emulsion) paints. That will cover the main options. You can find plenty of good paints in both categories.
manohara19 May 2021 19:48
So far, I haven’t looked into it in detail, but the company "Keim" has been recommended to me several times. Especially because they work in a “somewhat mineral-based” way. (I don’t know if this also applies to "Keim Biosil").
That means:
I am not familiar with Biosil, but I recommend taking a closer look at it.
driver55
19 May 2021 20:18
Mathodo schrieb:
I'll ask this way: which paint color have you used and had good experiences with?
Get your paint from a professional paint store. You really can’t go wrong with that.
If links here are automatically considered advertising and therefore deleted, I won’t mention any brand names either.
