Hausbautraum2014 May 2021 22:00Hello,
we are currently considering whether to install a solar power system. I have noticed there are various opinions on this topic, but individual factors also play a role. Apparently, it might not be financially beneficial for us, or I may be overlooking something.
Here is our current situation:
- Quote for a 5 kWp solar system with everything included: just under 10,000€ (approximately $10,000)
-> 500€ (approximately $540) annual depreciation
- Interest on 10,000€ (approximately $10,000): 100€ (approximately $110)
---> 600€ (approximately $650) annual costs
Income:
A 5 kWp system apparently generates about 4,500 kWh.
We currently consume 1,500 kWh annually, but there are only two of us so far.
So, I roughly save 800 kWh x 0.30€ = 240€ (approximately $260) for self-consumption and receive 3,700 kWh x 0.08€ = 300€ (approximately $325) feed-in tariff.
That makes a total income of 540€ (approximately $585).
The hard part to estimate is the share of self-consumption covered by the solar system. Since we are not home during the day and mostly use appliances in the evening, I find the 800 kWh out of 1,500 kWh estimate rather optimistic.
If not all new buildings around us had solar systems, I would not hesitate further, but maybe my reasoning is flawed?
What do the solar system supporters say?
Thanks for your assessment!
Income:
nordanney14 May 2021 22:09Hausbautraum20 schrieb:
-Offer for a 5 kWp solar system with everything just under 10kThat is the mistake. 10 kWp should cost around 11k net. Then the calculation looks different. 4,500 kWh sounds low as a yield.
The offer also seems very expensive to me. For us, it's around €11,000 for 9.8 kWp.
I think it’s also a matter of perspective. When I look at our consumption in the Sunny Home Manager and see what we use ourselves versus what we feed back into the grid, I’m glad to have the system.
hampshire14 May 2021 23:33Get a better offer and the invoice will be correct. What is the roof orientation? You will achieve higher self-consumption with an east-west system than with a south-facing one.
We are not home during the day and mainly use appliances in the evening,I always thought solar panels were for hot water?
Hausbautraum2015 May 2021 07:13Thanks for your answers!
Due to the small roof area (and roof windows), we can’t install much more than 5 kWp. I estimated the corresponding 4800 kWh from the internet. The roof faces south, which is worse for self-consumption but maybe better for feed-in than 4800?
I will definitely get another quote. However, travel costs, scaffolding?, electrician... cost the same for 5 kWp as for 10 kWp, and labor hours around Munich are expensive.
