ᐅ Which types of flooring are recommended for single-family homes? What does the building expert community suggest?
Created on: 14 Sep 2020 07:43
E
exto1791
We are slowly starting to consider the flooring for our planned single-family house and are still completely undecided.
We have an open-plan living-dining area with a kitchen. We believe that a seamless floor transition looks nicer than separating the kitchen from the living/dining area. For this reason, we want to have a uniform floor covering throughout.
Now the question: vinyl or tiles? We have already read about the pros and cons, but maybe we can get some first-hand tips or tricks here that might put some of the disadvantages into a more positive perspective?
1. Question: Is vinyl really safe to use in the kitchen? Is vinyl fully waterproof? How does vinyl flooring react if, for example, a knife slips from my hand and falls on the floor? Will I get immediate dents or marks? Are there vinyl floors that are significantly more resistant?
2. Question: How does vinyl respond to sunlight? Since we will have several large glass fronts in our living-dining area, vinyl "technically" seems to be excluded... Does vinyl actually deform? Is it true that vinyl, like parquet, fades significantly in sunlight?
3. Question: Is vinyl really only suitable for 10-20 years? What happens afterward? Do I have to replace the vinyl, or can it be refurbished or maintained?
--> We are considering tiling the entire area because then we would be "done," have a robust floor that works perfectly with underfloor heating, is simple, and very resistant to sun/fading/stains/impacts. We think generally that you can’t go wrong with tiles.
However, I see the problem that the tiles will likely stay in place for a lifetime, and I may not want or be able to replace them later due to the high effort involved. Also, any chip or damage to a tile will be visible for life since I can’t quickly repair it (true, vinyl also can’t be easily repaired, but I could replace the floor after 15-20 years). Another downside is cost. Tiles are generally more expensive, and I wouldn’t be able to install them myself (I don’t feel confident with tiles but feel okay with vinyl), so we are wondering what is best for us.
What flooring have you installed in your living/dining areas? What good or bad experiences have you had?
Now about the upper rooms:
1 bedroom and 2 kids’ rooms: vinyl/parquet/cork/laminate?
We are familiar with the pros and cons here as well. Parquet is "technically" out of the question because it is very expensive (is there good parquet for around 30€ (about $33)?). Opinions on vinyl are divided... We also have clear concerns (especially in the kids’ rooms) regarding plastic flooring... Are they really completely safe and non-toxic nowadays? If I pay attention to this, can I safely choose vinyl for the kids’ rooms? The kids’ rooms should be "good and affordable" above all. Cork might be an option? Laminate is somehow excluded because it is very noisy and offers no advantages over cork or vinyl.
Is parquet sensible for the bedroom? Here there is no fading, parquet is durable, and sunlight is limited. Very durable and might make the bedroom more visually appealing. What do you think?
We are open to any suggestions.
Where did you buy your flooring? From a hardware store? A specialist dealer? Are there recommendations, including manufacturers or models?
pagoni202019 Apr 2021 10:35I would personally question what @Myrna_Loy says, especially as a builder myself. If you come to a different conclusion on your own, that’s fine, but such "criticism" can actually help achieve a more error-free result by pointing out something you might not have noticed before or not paid enough attention to.
How often do we experience (at least I do) noticing something only after it has happened.
Sound is also perceived differently, even by the same person in a different environment.
pagoni2020 schrieb:
I would personally question what @Myrna_Loy says from the perspective of a builder. If you come to a different conclusion for yourself, that’s fine, but such "criticism" can lead to fewer mistakes if it helps you notice something you hadn’t considered before or hadn’t paid enough attention to.
How often do we (at least I do) only realize something after it’s already happened.
Sound is also perceived differently, even by the same person in different environments. Exactly, that’s why Myrna_Loy would never lay tiles—but I would. As you said, it’s always perceived differently 🙂
In the end, this isn’t really "criticism" but just a different opinion or preference when it comes to flooring 🙂
exto1791 schrieb:
Maybe for your 5.1 Hi-Fi system with subwoofer for 2,000€ 😀
It's still a living/dining room, not a dedicated music room 😀Off-topic, a multipurpose room as the central point of the house and family gathering place should also have a good TV, streaming services, and sound system,
or do you always go to the home theater in the basement?
Nida35a schrieb:
Off-topic,
a multipurpose room as the central living space and family gathering point should also have a good TV, streaming services, and sound system,
or do you always go to the home theater in the basement?If I need cinema-quality sound, I honestly just go to the movie theater.
No, seriously, I don’t place much emphasis on sound quality... a soundbar is completely sufficient for me; you definitely won’t notice any difference between tile and hardwood flooring. In the end, the furnishings are what really matter.
As I said, for perfect 5.1 surround sound with powerful subwoofers, it can make "some" difference.
But for me personally, this would never be a deciding factor when choosing a floor.
exto1791 schrieb:
A soundbar is completely enough for me; you definitely won’t hear any difference between tile and hardwood flooring.That’s good then, but you’re only your own standard.Similar topics
