ᐅ Front yard wall on a slope/gradient, what to do?
Created on: 29 Mar 2021 21:50
chewbacca123
we are currently in the process of finalizing the design for our front garden.
The right side is a bit tricky, as you can see in the pictures, there is a slope from the front door down to the right corner of the house. We would actually like to have a flower bed there, similar to the one on the left side. Now the question is, how should we retain the soil on the right? Would you build a concrete block wall? A railing would then need to be installed on top of the wall.
Things aren’t looking very ideal…
We’re a bit unsure at the moment.
One of the pictures shows the suggestion from our excavator operator.
Greetings and thanks
Modernes Einfamilienhaus mit weißer Fassade, schwarzem Sockel und dunklen Fensterrahmen.
Modernes weißes Einfamilienhaus mit dunklem Sockel, zwei hohe Fenster, Baumaterialien davor.
Modernes Haus mit Carport, zwei Autos; Kind in Blauem Hoodie malt Kreide auf Gehweg.
Weißes Einfamilienhaus, davor ein großer dunkler Erd-/Materialhaufen mit orange Markierungen.
Straßenszene: Steinmauer und weißer Zaun, orange Linien über Mauer, Hintergrundhaus.
tomtom7930 Mar 2021 08:33
I would place your stone wall in front of the light well and shape the terrain to the area on the right side of the house.
If you build the wall as planned, you will have a massive structure that will definitely require fall protection.
chewbacca12330 Mar 2021 10:27
If you build the wall as planned, you will have a bulky structure that definitely needs a fall protection barrier.
That’s a good idea too!
We are inspired by the posts here.
Thank you very much 🙂
Maybe we will add a nice bench in front of the well.
Exterior view of a white house front with terrace; orange bench, green shrubs, and stone path in the front yard.
11ant30 Mar 2021 11:13
chewbacca123 schrieb:
Explanations in what sense,
Well, what you drew there: the orange threads in the field—are those carrots or fireflies? And what are the blue fuzzies on the tennis net... I can only make very limited sense of what is supposed to be meant there.
haydee
30 Mar 2021 11:29
Oops, I guess I’m lacking imagination.
My interpretation:
Tennis net with blue fuzz = overgrown fence/trellis
Orange threads in the field = bark mulch
@chewbacca123
I prefer the suggestion with the bench.
chewbacca12330 Mar 2021 11:46
So what you’ve drawn: the orange lines in the field, are those carrots or fireflies, and what are the blue fuzzies on the tennis net... I can only understand very little of what is meant here.
Oh, no; the picture was sent by our excavator operator as an example, just to illustrate where the planting bed and the wall are.
The blue ones are gabions.
tomtom7930 Mar 2021 11:50
If a bank is an option, you could also cover the light well with gabions and put some planks on top as a bench. Neighbors have that, and it’s great for sitting while the children play in the residential street.
