ᐅ Sloped Site: Initial Floor Plan Idea & Request for Feedback
Created on: 18 Mar 2021 22:01
GaertM1
we have now started the first "internal" draft planning and I would be very grateful for any feedback – especially if there are any of our “ideas” that are completely off the mark...
Development Plan / Restrictions:
"Facts"
no development plan, last plot at the edge of a village area
Plot size: 330m² (approx. 21.8m x 14.8m / 71.5ft x 48.5ft)
Slope: about 7°
Clay-loam soil, limestone at shallow depth
Information according to building permit inquiry
Site coverage ratio: 0.6
Floor area ratio: 1.2
Street = building line
2 parking spaces
Number of storeys: max. 2 full storeys
Roof style: any
Eaves height 6m (20ft)
Ridge height 10m (33ft)
Client requirements
Style, roof type, building type: flat roof preferred, but e.g., also “modern barn” style
Basement with daylight from the slope as a lower ground floor, above that a “real” storey
2 persons (35, 36 years old)
Space requirement ground floor and upper floor: approx. 200m² (2,150 sq ft) total
Office: 2x home offices
Guest stays per year: none
Open architecture
Modern construction method
Open kitchen with kitchen island: yes
Number of dining seats: 4
Fireplace: no
Garage, carport: not essential, 2 parking spaces sufficient
Utility garden, greenhouse: as little garden as possible
Other wishes: KNX system, air conditioning for main rooms
Designer: do-it-yourself
What do you like most? Why?: main living areas all on one level
What do you dislike? Why?: bathroom and dressing room borderline “small”
Personal budget for the house, including fixtures: approx. 500,000 to max. 700,000 euros
Preferred heating system: we don’t really care
If you had to cut back, on which details or extensions
- Can be omitted: lounge on ground floor, pantry
- Cannot be omitted: guest WC on upper floor, dressing room, minimum clear ceiling height on upper floor 2.70m (better 3m / 9ft 10in)
Why has the design turned out as it is now?, for example:
“Optimizing” the eaves height while maximizing the use of setback distances
Minimize earthworks as much as possible (considering the soil...)
Have I completely misjudged any fundamental aspect? Is any detail of the design “absurdly expensive”?
Note 1: Views are just for a general idea of the plot situation at this stage – windows and so on still look pretty rough…
Note 2: Plan is drawn roughly to scale (5mm grid = 50cm / 20 inches), numbers in () are m²; north is bottom left on ground floor and upper floor plans, the beautiful view to the south is top right :-)
Already now: many thanks for all your feedback!!!
Modern two-story 3D house model with large window fronts on green area.
Modern white cube villa on raised base with carport ramp and garden
Floor plan of a building section with wine cellar, technical room, office, hallway, lounge, WC; terrace and parking spaces.
Hand-drawn floor plan of an apartment with living, cooking, dining, sleeping, bathroom, corridor.
Technical drawing on graph paper: cross-section of a building with upper and ground floor, length 2150.
Satellite image with orange, red-bordered plot on cadastral map.
GaertM1
19 Mar 2021 17:18
I always struggle a bit with this:
a) coming in with a very clear idea
or
b) "Hello architect, here is the plot, a house for two people, please design something, then we can discuss it :-)"
From what I’m hearing now, there are quite a few points in favor of option "b" :-)
rick201819 Mar 2021 17:32
Clearly B. Customization comes later. As a layperson, you simply don’t have the perspective, training, or experience to design something great and practical on a slope.
19 Mar 2021 17:51
icandoit schrieb:
The statement that the street equals the building line confuses me a bit in a village. Does this apply to the house or only to the garage or carport?
Are you sure you know what a building line is?
Anyway, the architect will be able to understand your plan.
GaertM1
19 Mar 2021 18:20
I am pretty certain about the building line. I already spoke with the building authority, and that was one of my questions... The answer was clear: “The house must be built directly on the street.” As mentioned before, all houses in the village area are also built on the street (with minimal deviations). Of course, I would leave any discussion about possible deviations to the architect :-)
Yaso2.019 Mar 2021 18:43
a) come with a very specific idea
or
b) "Hello architect, here’s the plot, a house for two, please design something, then we’ll talk 🙂"
I’m getting the impression that option “b” has some advantages 🙂
If you choose a, you get a.
Because then they will just try to implement exactly what you imagined, without really considering if it makes sense or not. Unfortunately, I speak from experience here as well.
If you go to an architect, definitely go with option b, and then see what you don’t like or what needs to be adjusted. If it still doesn’t work at all, you can always share your specific ideas later on.
haydee
19 Mar 2021 18:44
Let the architects do their work. Even if you are talking to a general contractor, just provide the basic guidelines. Our house, apart from the location, no longer resembles my initial sketches. Not even the number of rooms stayed the same.
