ᐅ Tips Before Starting Construction – What to Watch Out For?
Created on: 18 Mar 2021 11:11
E
exto1791
First of all: I’m not sure if there is already a thread like this, but nevertheless, I would find it very interesting to gather opinions, ideas, tips, tricks, etc., shortly before or during the construction phase, in order to avoid possible “sources of errors” that some homeowners made out of lack of knowledge.
These should mostly be “small details” that can be relatively easily changed or adjusted and don’t disrupt the entire plan.
We are not talking about:
--> I wouldn’t build a basement anymore
--> I would definitely get a garage in the future
But rather things like:
--> Make sure to install a conduit for the photovoltaic system
--> Wire your front door electrically to allow for technical upgrades later on
--> Install enough power outlets at certain spots to...
--> Have a water connection installed for an additional shower to create more options later
They can really be small things that bothered you afterward, that you would have done differently, but no longer have the chance to change, or that caused additional costs later on.
Topics related to kitchen, bathroom, or similar are also welcome.
We want to think of as many things as possible (which is of course nearly impossible and always depends on individual circumstances) — but surely some tips could still be helpful.
Looking forward to your input 🙂
E
exto1791
18 Mar 2021 13:37
Absolutely right – I know what you mean. I can easily plan a niche or even a projection above the washbasins either before or during the shell construction phase.
The difficult part is definitely the individual preferences – but that is exactly the point I want to make. It doesn’t have to suit everyone, but in the end, you can consider it and decide whether it’s worthwhile or not.
I
icandoit
18 Mar 2021 13:38
Coaxial cable in all living areas.
11ant18 Mar 2021 13:58
exto1791 schrieb:
First of all: I’m not sure if there is already a thread like this. Nevertheless, I would find it very interesting to collect opinions, ideas, tips, tricks, etc., shortly before or during the construction phase, in order to avoid possible “error sources” that some builders have made out of ignorance in the future.
Well, my unfortunately very poorly visited “Grütze” thread https://www.hausbau-forum.de/threads/gruetze-der-sammelthread-fuer-zerknuellte-grundrisse-co.30156/ has a different purpose.
exto1791 schrieb:
More like things such as:
--> Definitely install an empty conduit for the photovoltaic system
I always say whenever the topic of empty conduits comes up that you should not only install protective conduits for planned wiring but also proper empty conduits deserving the name.
What I would write into every builder’s memory book, if construction is really about to start: accept the finality of the planning, don’t wish to pull back the bullet already fired; write down any remaining change requests that occur to you now on the wish list for the next house. Start the grieving process for all further improvements that can no longer be implemented and clear the way for the landscaping phase: flower beds, pond & co.!
I
icandoit
18 Mar 2021 14:07
Photo documentation of the pipes, labeling of heating circuits and their locations, keep all documents organized and properly stored.
nordanney
18 Mar 2021 14:08
icandoit schrieb:
Coaxial cable in all living rooms.
For what purpose? For satellite reception?
I would rather suggest using Sat to IP directly instead of any coaxial cables.
I
icandoit
18 Mar 2021 14:10
nordanney schrieb:
What for? For satellite reception?
Yes.
